JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Drivers fuse box removel.
jomo
17-09-2020, 05:22 PM
As one know how easy it is to remove/ get access to the drivers fuse box as i need to swap the relay for the indicators as im fitting leds.
A walk through with pics would be best...
jomo
17-09-2020, 05:22 PM #1
17-09-2020, 05:36 PM
can't you just attach a load resistor to the LED wiring?
17-09-2020, 05:36 PM #2
17-09-2020, 06:04 PM
If you undo the 2/3 bolts in it (10mm) it should pull forward enough to change it.
17-09-2020, 06:04 PM #3
jomo
17-09-2020, 08:45 PM
el_bandido can't you just attach a load resistor to the LED wiring?
Yes i could, but got the led relay now so gonna do it the right way.
Sparkystav If you undo the 2/3 bolts in it (10mm) it should pull forward enough to change it.
As also ways Marc bails me out, Cheers Stav...
jomo
17-09-2020, 08:45 PM #4
18-09-2020, 07:41 AM
you may end up with a few scratches on the hand but it can be done
18-09-2020, 07:41 AM #5
jomo
18-09-2020, 02:29 PM
Just got a new kitten, so its not like id notice them lol...
jomo
18-09-2020, 02:29 PM #6
Views 509
27-11-2021, 06:01 PM
Views 523
17-03-2019, 04:59 AM
Views 1,797
28-11-2018, 11:57 AM
Views 1,541
09-05-2018, 07:45 AM
Replies 31
Views 3,118
24-04-2018, 07:22 PM
Last Post by JeffMcC
Replies 18
Views 1,655
24-12-2017, 06:07 AM
Last Post by N2KHL
