Cluster swap
Cluster swap
Hi
Anyone have done a swap the Altezza manual cluster onto a Is200/300?
Just curious :tongue_smilie:
I did once, but the rpm dial is wrong because the altezza gives 4 pulses per revolution, and the is200 gives 6. So the rpm gauge reads 1.5 times higher than the should. But you can get adapters to correct it if you want.
Sent from my Xperia S using Tapatalk 2
Does the harness plug are the same beside need getting an adapter for the correct rpm reading?
Thanks
Yes the plugs on the back are exactly the same for the IS200 and Altezza.
sprinter2012 Yes the plugs on the back are exactly the same for the IS200 and Altezza.aww man ... now so temtep to have the swap.... now just havta look for any breaker whos selling it
http://www.dakotadigital.com/index.cfm/p...prd127.htm would do the job, assuming the car uses a fairly standard rev signal from the coil -ve, and it isn't sent over CANBUS.
altenatively you can use a kmh to mph convertor.
its roughly the same,wont be perfect but better than nothing and a lot cheaper.
i put in a rs200 in mine. some things work and some don't.here is the one i have with the digital kmh readout on ebay but it only goes upto 180 and is kph not mph so you will need to convert it some how.
http://www.ebay.co.uk/itm/Toyota-Altezza...337c61ebfe
:ohmy: wow :Chair:
what a price to pay for the parts.... anyone reckon the right price to pay?
