JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension lower suspenion arm bushes difference
21-07-2017, 01:49 PM
hi there,
what are the difference between these two?
http://www.rhdjapan.com/jdm-low/Cusco-Sp...T-18-60435
http://www.priracing.com/product.php/258...ner-bushes
thnaks
21-07-2017, 01:49 PM #1
hi there,
thnaks
21-07-2017, 03:04 PM
They look like two completely different things. I'd seen those PRI bushes before but I didn't think that was what you were after, are you sure they're the bushes you need ?
I can't imagine you could use that metal Cusco bearing in place of whatever's on your IS200 at the moment, it's probably the wrong size for a start, and I have no idea whether that sort of thing is compatible anyway.
21-07-2017, 03:04 PM #2
21-07-2017, 03:30 PM
i just need the bushes thats it because the bushes have cracked.
the metal ones came when i was searching stuff for the altezza so if they fit a altezza should be a is200??
21-07-2017, 03:30 PM #3
21-07-2017, 03:33 PM
Asi i just need the bushes thats it because the bushes have cracked.
Whereabouts do they fit an Altezza though, i.e. for what part ? Are you sure they're for the lower suspension arms ?
21-07-2017, 03:33 PM #4
aaronabbott
21-07-2017, 03:40 PM
you need a new lower suspension arm,ive told you this before Sad,as i was told this by WIM when they found out mine was knackered that you cant buy them seperate
aaronabbott
21-07-2017, 03:40 PM #5
21-07-2017, 03:55 PM
im sure they are for the lower suspension arms
@arraonabbott: well the second link have poly bushes for the lower suspension arms and they are for the is200. so if the bushes are needing changed then i could get the poly ones
21-07-2017, 03:55 PM #6
aaronabbott
21-07-2017, 03:56 PM
what you waiting for then,cheaper than a new lower armBlush
aaronabbott
21-07-2017, 03:56 PM #7
21-07-2017, 04:05 PM
yes they are cheaper than a new arm but i just want to know the difference between the metal ones and the poly ones.
going to get it done might aswell get better ones.
21-07-2017, 04:05 PM #8
aaronabbott
21-07-2017, 04:13 PM
im sure poly are better
aaronabbott
21-07-2017, 04:13 PM #9
21-07-2017, 04:44 PM
right thanks mate
21-07-2017, 04:44 PM #10
right thanks mate
Views 727
22-10-2019, 07:53 PM
Last Post by dj0nes
Views 1,708
14-07-2019, 12:36 PM
Replies 23
Views 3,218
09-07-2019, 12:10 PM
Views 1,296
16-07-2017, 10:10 AM
Last Post by aaronabbott
