JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Engine cuts out when warm
spud1973
09-11-2020, 10:45 AM
My supercharged is200 keeps cutting out when warm then wont start again for about 5mins. It is now getting on my nerves. The only code that comes up on a scanner is to do with a 02 sensor which I already know about due to no cats what so ever.
Is it more than likely to be the crank sensor??
Please help guys im at my wits end
spud1973
09-11-2020, 10:45 AM #1
09-11-2020, 12:13 PM
Is it just the rear O2 sensor that comes up?
09-11-2020, 12:13 PM #2
spud1973
09-11-2020, 12:36 PM
Yes mate I have got that 02 box off you but that didn't cure it so I reckon that is down to my wiring, going to wire it under the seat instead of in the bay. That has never given me a problem though, this new issue however is someone was saying it could be the tte black box but im not so sure.
In my previous experience with vauxhalls when a similar thing happened it was the crank sensor. It's weird as the only thing the scanner is picking up on is the 02 sensor.
spud1973
09-11-2020, 12:36 PM #3
09-11-2020, 02:22 PM
Hmm it is odd not picking anything else.
09-11-2020, 02:22 PM #4
spud1973
09-11-2020, 02:25 PM
Just had it round my mate's garage hooked upto a snap on solus left it on idle for about half hour and nothing didnt cut out or anything now I am properly confused
spud1973
09-11-2020, 02:25 PM #5
09-11-2020, 07:10 PM
are you doing anything when it cuts out. ie idling, crusin, booting it?
09-11-2020, 07:10 PM #6
spud1973
09-11-2020, 08:00 PM
The times it has happened I have gone from standstill to setting off and then it dies. It has done it on a normal take off and also when I gave it some beans.
spud1973
09-11-2020, 08:00 PM #7
spud1973
10-11-2020, 09:39 AM
Figured it out the car is heavily overfueling so when at idle or standstill it is flooding causing the cutting out when warm. So time for a new black box.
spud1973
10-11-2020, 09:39 AM #8
10-11-2020, 10:41 AM
Very odd to be overflooding!
You def got the right wiring with the o2 sensor box? Cause the other 2 sensors control fuelling.
10-11-2020, 10:41 AM #9
14-11-2020, 09:36 PM
I would double check the connections mate just incase
14-11-2020, 09:36 PM #10
Views 423
15-04-2023, 09:06 AM
Views 572
15-01-2023, 08:08 AM
Views 1,117
17-08-2022, 09:38 AM
Last Post by mattlaw
Views 662
23-04-2021, 03:50 AM
Last Post by S
Views 972
01-04-2021, 08:42 AM
Views 449
10-03-2021, 05:19 AM
Views 884
25-06-2020, 04:13 PM
Replies 18
Views 2,138
20-02-2020, 01:03 PM
Views 2,074
18-11-2019, 10:04 AM
Views 1,092
16-11-2019, 04:05 PM
