JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 2 coil packs breaking at once. What are the chances?
JayJay1374
24-11-2019, 10:23 AM
Alright. Last night I fitted my bigger supercharger pulley (160mm) since then the car has ran fine. Until today I changed into 2nd at a junction. Didn't put the engine under strain or anything and it started misfiring. After using a obd reader it was cylinder 1&5. After removing the coil packs and swapping then with different cylinders I got errors on cylinders 2&4 which indicates 2 failed coil packs.
So is it due to age and mileage (12years & 135000miles) or due to the bigger pulley. But how come both would go at once??
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
24-11-2019, 10:23 AM #1
Rolex
24-11-2019, 10:55 AM
My IS200 did the same when I fitted my charger. It had 130,000 miles on the car and blew out two coil packs on the first outing. Probably just age as I would imagine they are probably the ones from new.
Rolex
24-11-2019, 10:55 AM #2
24-11-2019, 11:07 AM
I don't know why they go down 2 at once, just always seem to.
But 1&5 are the same firing cylinders, maybe that has something to it?
24-11-2019, 11:07 AM #3
JayJay1374
24-11-2019, 11:22 AM
Well now I've swapped the coilpacks it's 2&4 that are missing. Do they run together? Well I've managed to find someone with some locally so I will be get some new ones tomorrow. Might get 4 off him just incase!
JayJay1374
24-11-2019, 11:22 AM #4
24-11-2019, 11:36 AM
No but I'm thinking its maybe related, once their failed their failed so they will follow where you move them.
24-11-2019, 11:36 AM #5
JayJay1374
24-11-2019, 11:38 AM
Ah right I see. I havnt touched anything. Might have to get the emanage on and get a map quicker than I thought!
JayJay1374
24-11-2019, 11:38 AM #6
Jon
24-11-2019, 04:58 PM
JayJay1374 Alright. Last night I fitted my bigger supercharger pulley (160mm) since then the car has ran fine. Until today I changed into 2nd at a junction. Didn't put the engine under strain or anything and it started misfiring. After using a obd reader it was cylinder 1&5. After removing the coil packs and swapping then with different cylinders I got errors on cylinders 2&4 which indicates 2 failed coil packs.
Slightly off topic, but what engine management are you using with the 160mm pulley? Standard and FCD or Emanage etc?
Jon
24-11-2019, 04:58 PM #7
JayJay1374
24-11-2019, 05:05 PM
At the minute I'm running Patrick's fuel cut defender. I have an emanage. But can't be bothered to do load of soldering!
JayJay1374
24-11-2019, 05:05 PM #8
Jon
24-11-2019, 05:12 PM
JayJay1374 At the minute I'm running Patrick's fuel cut defender. I have an emanage. But can't be bothered to do load of soldering!
does it run alright with Patricks black box? have your upgraded the injectors?
Reason I ask, is I have Patricks black box and 1JZZ injector which is running fines, and a 160mm pulley waiting to be fitted.
Jon
24-11-2019, 05:12 PM #9
JayJay1374
24-11-2019, 05:31 PM
It ran fine in general. Just randomly started misfiring! I have standard injectors aswell!
JayJay1374
24-11-2019, 05:31 PM #10
Views 344
31-01-2019, 12:20 AM
Views 788
13-08-2018, 11:25 PM
Last Post by northernmonkey
Views 1,373
12-08-2018, 09:54 AM
Views 962
02-07-2017, 09:48 AM
Last Post by garyskisplym
Views 1,057
20-04-2017, 07:49 AM
Replies 29
Views 1,468
16-12-2016, 04:34 AM
Last Post by russelllinn
Replies 18
Views 914
13-09-2016, 11:50 PM
