JapCarForum Car Manufacturers Lexus/Toyota Dual vvt-i control?
Dual vvt-i control?
Dual vvt-i control?
20-01-2021, 12:20 PM
I can't actually seem to find a concrete answer on this from anywhere on the web, but does anyone have any experience with after market ecu's that can effectively control dynamic vvt-i (such as in the altezza beams engine)?
I'm not talking about having it either on or off, as if it's permanently on it seems to advance to 15 degrees and stay there, I mean properly control it.
Edited 03-03-2013, 04:06 PM by el_bandido.
20-01-2021, 12:20 PM #1
20-01-2021, 12:46 PM
Camcon does that I believe. Issue is the ecu will always fight it.
20-01-2021, 12:46 PM #2
20-01-2021, 12:49 PM
A stand alone ecu will always fight dual vvti? Sorry if I'm being extremely dense.
20-01-2021, 12:49 PM #3
S
20-01-2021, 01:15 PM
no the standard ECU is a self learning ECu so if you change any settings with the Camcon the standard ECU will just adjust its settings to try and get it running back to "normal"
Its also why IS200's cant be mapped IIRC
S
20-01-2021, 01:15 PM #4
wullie_trd
I thought the apexi PFC could do this, not 100% though
wullie_trd
20-01-2021, 01:15 PM #5
20-01-2021, 01:19 PM
I'm talking about a stand alone. It will not be in an altezza or using the altezza ecu.
Edited 03-03-2013, 05:04 PM by el_bandido.
20-01-2021, 01:19 PM #6
Kevpr
20-01-2021, 02:02 PM
I had a brief look for my car. I'm pretty sure an Alexi power FC can. Other than that I think your looking at motec. Maybe link?
Kevpr
20-01-2021, 02:02 PM #7
20-01-2021, 02:13 PM
Ah didn't realise you wanted a standalone. The link does it I believe.
20-01-2021, 02:13 PM #8
20-01-2021, 02:15 PM
Cool, thanks. Atom should be enough for 4cl shouldn't it?
20-01-2021, 02:15 PM #9
20-01-2021, 05:04 PM
but not sure if the atom has enough outputs/inputs. id go with the storm myself
20-01-2021, 05:04 PM #10
Replies 26
Views 1,732
04-02-2021, 05:24 PM
Last Post by Is250Brad
Views 412
19-02-2020, 12:57 PM
Last Post by Tomo1978
