1g-gze diagrams?
1g-gze diagrams?
Can anyone get hold of these? I'm trying to work out if the supercharger and intake arrangement will bolt on to the 1g-fe. Also trying to work out if it will fit in the is200 engine bay.
Why? The inlet won't fit the spacing is different on the intakes afaik. You'll have to lose the power steering to fit the gze supercharger as that where it fits.
Edit your right its the ac pump.
Inlet isn't such a problem, I'm just trying to work out what the bracket arrangement is for fitting the actual SC and whether or not the inlet is required.
hi i have an original set of instalation instructions for the supercharger these are the ones that come with it when they were new not sure if these will help you it has all the original part nu and a photo of every step of installing them is about 30 pages long though
