JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications about comp ratio
about comp ratio
about comp ratio
gc8_g_r
05-03-2020, 02:27 PM
Hi, I am wondering what comp ratio it is when using 1g-gte rod and piston in our engine.
someone knows?
cheers
gc8_g_r
05-03-2020, 02:27 PM #1
someone knows?
cheers
05-03-2020, 11:20 PM
1g-fe compression ratio is 10:1 I think, this will drop to 8.5:1 if you use the GTE rods and pistons.
I think the above is correct, Stav will probably be along to correct me if I'm wrong!
05-03-2020, 11:20 PM #2
06-03-2020, 12:53 AM
I must admit I'm not fully Upto speed on the workings of compression ratios. So no help at the mo. something I must read up on.
06-03-2020, 12:53 AM #3
gc8_g_r
06-03-2020, 05:30 PM
el_bandido 1g-fe compression ratio is 10:1 I think, this will drop to 8.5:1 if you use the GTE rods and pistons.
even same piston and rod, with different head, compression ratio is different.
gc8_g_r
06-03-2020, 05:30 PM #4
07-03-2020, 01:36 AM
as far as I can work out, it's the pistons that change the comp ratio. I'm planning on using the GTE rods with the FE piston in my FE engine so I get the stronger rod and maintain the higher compression ratio.
07-03-2020, 01:36 AM #5
gc8_g_r
07-03-2020, 03:28 AM
el_bandido as far as I can work out, it's the pistons that change the comp ratio. I'm planning on using the GTE rods with the FE piston in my FE engine so I get the stronger rod and maintain the higher compression ratio.
mate, i was think about the same way, plz tell me your result laterSmile
I am always wodering how strong the stock FE pistonis.
gc8_g_r
07-03-2020, 03:28 AM #6
07-03-2020, 04:00 AM
It would seem it's the rods that are the weak point of the FE engine, not the pistons. My results will be a long way off mate, I'm not in a position to do an engine rebuild yet (until at least September). I've only just finished getting the rest of the car ready for a speed upgrade.
07-03-2020, 04:00 AM #7
Views 211
28-01-2021, 10:29 AM
