JapCarForum Cars, Cars, Cars! General Car Maintenance anyone replaced top ball joints
10-03-2020, 12:39 AM
Hi all,
Last year my mot tester said he had a little excess play and depending on how much I drive I.e miles whether it would be ok for the next one.
So I'm just going to change them for piece of mind more than anything
Is there anything I should be weary off when doing this job I'm pretty sure its fairly easy to do but just making sure I don't miss something I need to know
10-03-2020, 12:39 AM #1
Hi all,
James S
10-03-2020, 01:22 AM
Hi Pat, I fitted coilovers yesterday. Was fairly easy to split the front top ball joint. Not sure how you get it off the wish bone though.
But my last is200 the one same colour as yours, when I took that for Mot the first time. The tester there said there was a bit of play in the ball joints, but there was nothing wrong with them the next time I took it for Mot somewhere else. So might be worth getting a second opinion?
James S
10-03-2020, 01:22 AM #2
10-03-2020, 11:19 PM
Cheers james,
There a cheap part so may have a go and see what the outcome is
10-03-2020, 11:19 PM #3
Cheers james,
James S
11-03-2020, 12:23 AM
No worries, let us know how you get on, coz I put a little hole in the boot when splitting mine, so will have to change it at some point.
Just get a hammer and a splitter (these sell on eBay for a few quid).
The pin and castle nut come off easily. Then just go to work with the hammer, tapping around the joint. I only needed to use the spliter on one side. Watch out when it pops out, coz the hub will drop and the upper arm will spring upwards too.
It's pretty straight forward, give us a shout if you get stuck.
James S
11-03-2020, 12:23 AM #4
11-03-2020, 06:09 AM
You can avoid the hub dropping by putting the castle nut back on a few turns :thumbup1:
11-03-2020, 06:09 AM #5
Views 1,395
05-03-2021, 09:33 AM
Last Post by kevinsgs300
Views 531
03-01-2019, 11:58 AM
Views 555
25-03-2018, 08:36 AM
Last Post by D6NGR..
Views 547
26-11-2017, 12:12 PM
Last Post by widnes_is200
