Running a 1uz with no ecu
I'm in the middle of finishing another page of my "bat **** car ideas" book and I've got to the 240z build. Basically, I want the 1uz as a platform (non-vvti) but I want to drag it back to the 70s for that authentic 240z kind of theme. Plus an 8 throttle body, carbed v8 will sound amazing.
As far as I can work out, I'll need:
carburettors, probably weber carbs
distributor
what else? I assume I'd need something to control the timing, so is that possible without an ECU?
Could I just replace it with a pair of (for instance) old Honda distributors? I take it I'd have to set the timing manually and just leave it from then on?
