JapCarForum Club Sponsor Auto Rae Chem New retail range - maxolen
AutoRaeChem
17-04-2020, 10:48 AM
We have taken on board Maxolen Car Care Products.
Here's some of our most popular products;
Wheel Cleaner
[Image: wheelcleaner_zps37fb9c60.jpg]
Get those wheels to sparkle again. The style and condition of wheels can have a major effect on the overall appearance of a car. Maxolen Wheel Cleaner has been engineered using the latest synergy technologies and contains a scientifically balanced blend of acidic cleaners designed to rapidly dissolve brake dust and contaminants from most wheel types . Removes stubborn deposits such as: Heavy brake dust, Oil, Grease & Road dirt IMPORTANT: Use only on wheels that are cool to the touch. Clean one wheel at a time. Always thoroughly rinse wheels after cleaning.
Size 500ml @ £8.99 P&P £2.00
Sticky Stuff Remover (T&G)
[Image: stickystuff_zpsd1693818.jpg]
Dissolves Tar, Glue & Graffiti!
Tar deposits are a constant threat to your vehicle's paintwork, leaving it bumpy to the touch and potentially causing permanent staining. This Intensive Tar Remover dissolves a wide variety of contaminants, allowing them to be washed away in the normal washing procedure or can be wiped clear with a cloth. Removes: Tar, Grease, Adhesives, Silicones, Tree sap, Fuel stains, Graffiti and even over spray if your car has been in a paint shop. Can also be used to remove oil-based stains from synthetic carpets.
500ml @ £10.49 P&P £2.00
Super All Purpose
[Image: superallpurpose_zpsa001a6fc.jpg]
Want to get those stubborn coffee, oil, blood, dirt stains away use our great smelling, low foaming cleaner which offers a blend of surface-active ingredients and deodorising agents which "deep clean" your upholstery with the minimum of effort on your part! The easy to use, spray and wipe formula can be used to clean: Synthetic fabric upholstery, Carpets, Roof linings, Vinyls, Soft tops, Plastics this is a true multi purpose cleaner. (For use on lighter fabrics use Maxolen Universal Cleaner) Use it as a cleaner in the car, home, caravan, motor home, boat, aircraft etc.
500ml @ £9.99 P&P £2.00
Car Shampoo & Self Dryer Wax
[Image: shampooampwax_zps484b0fc8.jpg]
Want the best result for your paintwork when washing your car this specially formulated shampoo smells as though it has come straight out of the sweet shop, it is super concentrated so a little goes a long way to protect and restore.
Add a few cap full’s to a bucket of water and then apply with a wash mitt or sponge, rinse with clean water and watch the water bead off the paintwork, (Can also be used through a foam lance)
dilution 1-200.
500ml concentrate @ £8.99 P&P £2.00
Liquid Detailing Wax
[Image: liquiddetailwax_zps2bfcce27.jpg]
Get that silky smooth wet look finish with our liquid wax, its primary use is on the finishes of cars, trucks, buses and aircraft where durability, high gloss and lasting protection are paramount. Very easy to use and requires minimum rubbing or buffing. Clear coat safe.
500ml @ £7.95 P&P £2.00
Should you wish to order a product then please just send a payment along with your order through to paypal @ [email protected]
Edited 29-05-2013, 08:24 PM by AutoRaeChem.
AutoRaeChem
17-04-2020, 10:48 AM #1
Wheel Cleaner
Super All Purpose
dilution 1-200.
AutoRaeChem
17-04-2020, 11:09 AM
website updated to http://www.cardazzle.co.uk
AutoRaeChem
17-04-2020, 11:09 AM #2
Views 131
11-07-2022, 02:04 AM
Last Post by AutoRaeChem
Views 194
19-06-2020, 12:51 PM
Views 119
19-06-2020, 12:48 PM
Views 99
07-06-2020, 12:32 AM
Views 147
22-05-2020, 10:19 AM
Views 94
18-04-2020, 04:22 AM
Views 258
13-10-2018, 03:31 AM
Views 244
26-12-2017, 03:33 AM
