JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning decat manifold
decat manifold
decat manifold
Pages (3): 1 2 3 Next
buzzard2011
18-04-2021, 12:53 PM
hi all,
how difficult is it to decat the original manifold on a is200,is it a matter of beating the cats out or is cutting them out the better solution?
and once they are out will i need any modification on the sensors?
i was thinking of buying a second hand manifold and tampering with it a bit instead of buying a expensive stainless one?
any help greatly appreciated as always.:thumbup1:
buzzard2011
18-04-2021, 12:53 PM #1
hi all,
specializedfsr
28-03-2023, 06:46 AM
I have just bought a stainless one from the state's and now have the problem of the post cat sensors. Was thinking of extending them to behind the main cat but not sure if anyone else has had any success with that mod! Manifold was only £170 incl taxes, so not worth dicking about with std manifold although lots of people have just banged the insides out of them!
specializedfsr
28-03-2023, 06:46 AM #2
29-03-2023, 06:48 AM
So you've bought a stainless system, why would you want to extend the sensors?
29-03-2023, 06:48 AM #3
specializedfsr
29-03-2023, 07:56 PM
I have done away with the std manifolds with cats, so was going to attempt to fit post cat sensors behind the main cat! Will that work??
specializedfsr
29-03-2023, 07:56 PM #4
30-03-2023, 06:45 AM
Why would you got them there? Why not just on the manifold?
30-03-2023, 06:45 AM #5
specializedfsr
30-03-2023, 07:52 AM
Pre cat sensors staying on the manifold but post cats need to go after the main cat to avoid eml. Does that make sense?
specializedfsr
30-03-2023, 07:52 AM #6
mattlaw
31-03-2023, 09:19 PM
Just fit an emulator
mattlaw
31-03-2023, 09:19 PM #7
specializedfsr
01-04-2023, 02:36 AM
Can't seam to find them anywhere mattlaw, that was my first option!
specializedfsr
01-04-2023, 02:36 AM #8
01-04-2023, 07:38 AM
I'm a little confused. There is three sensors on the IS200.
Two in the manifold, and one post cat.
If you've removed all the cats it shouldn't affect the front two as they are used for fuel trimming.
The last one will bring up an ecu light.
You can either fit an emulator like Matt says or a spacer to draw it back a little and that can sometimes work.
01-04-2023, 07:38 AM #9
specializedfsr
02-04-2023, 07:02 AM
Two in the manifold are staying so just the one that tests the cat is working. Why can't I just put it after the main cat. Don't want to be doing the job twice. Live to get it right first time. IS300 by the way !
specializedfsr
02-04-2023, 07:02 AM #10
Views 1,773
27-05-2024, 08:34 PM
Last Post by bigdave1701
Views 1,662
29-09-2018, 08:25 PM
Last Post by ormi
