JapCarForum Trade Area Wanted Supercharger clutch/throttle switch
possel
19-04-2021, 05:58 PM
After the above ASAP, I don't no if its safe to run the supercharger 24-7 anyone got any ideas?
possel
19-04-2021, 05:58 PM #1
19-04-2021, 08:04 PM
What info you a after exactly?
19-04-2021, 08:04 PM #2
possel
19-04-2021, 08:08 PM
If its ok to have it on all the time, I may just get a on of switch, or wire it up to the throttle position (that's if the voltage varies on the amount the throttle is pressed)
possel
19-04-2021, 08:08 PM #3
possel
19-04-2021, 08:09 PM
Superchargers a new to me, had turbos in the past
possel
19-04-2021, 08:09 PM #4
19-04-2021, 08:13 PM
From what I know own superchargers, you can either have a clutch that turnsit oneor off,
Or you can have a bypass. Controlled by either the throttle or inlet pressure. So it closes once the throttle is open. Or inlet pressure rises.
19-04-2021, 08:13 PM #5
possel
19-04-2021, 08:16 PM
Ok the first 1 I get but the second one??
possel
19-04-2021, 08:16 PM #6
19-04-2021, 08:20 PM
A pipe that bypasses the charger, so when the throttles closed the air just goes back around the charger rather than pressurising the pipework.
It has a butterfly valve on it with either a spring and additional throttle cable, or an actuator like a turbo.
So either the throttle pulls the bypass shut when you push the throttle causing it to pressurise the pipework, or you have an actuator and as the charger gets faster and pressurises the pipework and inlet it closes the bypass using manifold pressure.
19-04-2021, 08:20 PM #7
possel
19-04-2021, 08:27 PM
So I can't just have it on all the time?
possel
19-04-2021, 08:27 PM #8
possel
19-04-2021, 08:54 PM
I have just been reading up on it, an defo going to go for the valve type as its a lot easier to do then try and get this switch thing. Thanks for your help ��
possel
19-04-2021, 08:54 PM #9
possel
20-04-2021, 09:59 AM
Am I right in thinking that as long as the blitz pulley is modified to constant and put a bypass valve in the system it will be fine? Does the valve fully close as soon as the throttle is pressed? Or will I only get boost when it's foot to the floor?
possel
20-04-2021, 09:59 AM #10
Views 301
23-05-2024, 08:03 PM
Views 268
18-07-2022, 12:30 PM
Last Post by Xtremist
Views 245
22-03-2022, 09:22 AM
Last Post by Alpine89
Views 465
10-03-2022, 04:36 PM
Views 649
16-02-2022, 07:22 AM
Last Post by specializedfsr
Views 503
04-10-2021, 07:13 PM
Last Post by NappyBoy
Views 276
10-08-2021, 04:15 PM
Views 338
06-05-2021, 09:10 AM
Last Post by lex2oos
Views 1,646
28-01-2021, 04:46 PM
Last Post by sprinter2012
Views 648
23-11-2020, 05:11 PM
Last Post by JayJay1374
