Can anyone help?
Can anyone help?
Hi everyone,
I've noticed in the last few weeks that when I haven't got much fuel in the car and I go around a corner with more than half throttle it cuts out, not enough to stall the car but is still a f****### pain, and its never done this before even with less fuel. Also after a long run on the motorway last weekend it done it for a few mins after? You can here the revs changing slightly and it has never done this before. I'm not sure wether it could be fuel filter or maby fuel injectors?
Anyone had this problem before? If so what was it and how did you fix it?
If not dose anyone have any idea what it might be?
Thanks for any help.
Lewis.
It's because the tank is in 2 halves. If you go round a corner the fuel goes to the other side.
There is a jet pump that pulls it back across but if your really low it won't.
Sparkystav It's because the tank is in 2 halves. If you go round a corner the fuel goes to the other side.
