JapCarForum Cars, Cars, Cars! General Car Maintenance Honda CRV automatic gearbox issue
03-06-2020, 12:39 PM
Honda CRV 2000 petrol automatic
Been driving this car a while and developed an intermittent fault which has now got worse.
When driving the car suddenly looses acceleration rpm goes up but the car slows down as if its in neutral (it's not I checked)
Seems odd I drove it round the fields today no issues but put it back on the road and its hit and miss I think it's electrical but before searching the car etc thought I would ask....
And ideas guys and girls
03-06-2020, 12:39 PM #1
03-06-2020, 12:51 PM
Not a clutch issue then? Just a first thought if revs are rising whilst the car decelerates?
If it's electrical then the best man to fix it is probably.......... you!
03-06-2020, 12:51 PM #2
03-06-2020, 01:15 PM
Nah it's an auto it's. a strange one...
03-06-2020, 01:15 PM #3
03-06-2020, 02:01 PM
Does it not still have a clutch? How does it not stall every time you stop? Or is there some kind of torque converter wizardry going on?
03-06-2020, 02:01 PM #4
03-06-2020, 02:38 PM
Torque converter I assume
It's really bizarre I'm tempted to go out and break down save the Agro lol
03-06-2020, 02:38 PM #5
04-06-2020, 12:13 AM
if its anything like my autobox, id hazard a guess at the gear change timing solenoid or something similar.
have you checked the fluid levels?
04-06-2020, 12:13 AM #6
04-06-2020, 01:47 AM
Check fluid, if it smells like burnt toast the fluid is knackered and probably the 'box also. New fluid may extend the 'box life a short while but will more then likely destroy what's left. On a brighter note it could be electrical.
04-06-2020, 01:47 AM #7
reganlives
04-06-2020, 01:51 AM
Is it a CVT box?? Probably a solenoid or something but I would agree, check the fluid.
reganlives
04-06-2020, 01:51 AM #8
04-06-2020, 01:54 AM
All fluid seems fine have tipped everything up no funky smells yet
04-06-2020, 01:54 AM #9
johnh
19-06-2022, 09:29 PM
I think it should be the same box as in my smx? My does odd things as well sometimes like when you put your foot down and it drops a gear it kinda drops to 2nd hits neutral and then 2nd again all in a second or two. I've read about and it seems quite common. Lot of people say a gearbox service helps, I put a prolong gearbox treatment in mine as and its cut it down a fair bit, gear changes are much smoother as well.
johnh
19-06-2022, 09:29 PM #10
Views 823
13-06-2019, 01:38 AM
Replies 36
Views 2,598
10-09-2018, 10:26 PM
Views 562
04-07-2018, 09:51 AM
Last Post by jomo
Views 877
17-01-2018, 04:36 AM
Last Post by daz
Views 1,222
05-01-2018, 10:45 AM
Last Post by Threadkiller
Views 610
23-12-2017, 12:33 AM
Last Post by Dan_Turism0
Views 679
23-08-2017, 07:33 AM
Views 475
12-08-2017, 12:17 AM
Last Post by rosey1955
Views 472
07-07-2017, 10:24 PM
