JapCarForum Trade Area Selling Hd foam lance
Hd foam lance
Hd foam lance
AutoRaeChem
04-06-2020, 12:43 AM
Option 1 HEAVY DUTY FOAM LANCE 160 BAR /2300PSI + Fitment + 500ml Pearl Shampoo @ £39.95 delivered UK mainland.
Option 2 HEAVY DUTY FOAM LANCE 160 BAR /2300PSI + Fitment + 5L Snow Foam @ £49.95 delivered UK mainland.
**IMPORTANT** YOU WILL NEED TO STATE WHICH FITMENT IS REQUIRED
KARCHER DIY / HD SERIES, KEW/ALTO/NILFISK, LAVOR, KRANZLE, M22, BOSCH.
Payment
Credit cards call 07979 758884
Paypal [email protected]
Website: http://www.cardazzle.co.uk
For information: The 1L foam bottle attaches directly to your pressure washer gun. Maximum pressure 160bar, 20L/min, 60 degrees. Variable spray nozzle with fully adjustable chemical dilution switch. Simply connect this to your gun and fill the bottle with 1" SNOW FOAM TOPPED UP WITH WATER and the nozzle will pull air through to mix your foaming agent to create a foam bath effect. The width of the spray can be adjusted by turning the end nozzle. The strength of the mix can be adjusted by turning the top dial. To add more water to the mix turn the dial to the plus (+) symbol. For a stronger mix turn the dial to the minus (-) symbol.
Should you require any further information then please do not hesitate to contact me via email on [email protected]
AutoRaeChem
04-06-2020, 12:43 AM #1
Payment
04-06-2020, 01:34 AM
hi rach, ive got one of those expandable blue xhose things, is there any connectors that can attach the lance to the xhose?
04-06-2020, 01:34 AM #2
reganlives
04-06-2020, 02:21 AM
Rachel, do you do replacement triggers/lances by any chance for Lavor pressure washers? Its a superwash 160
reganlives
04-06-2020, 02:21 AM #3
AutoRaeChem
04-06-2020, 07:35 AM
The foam lance is only available for a pressure washer
For a hose you would need to look at a Gilmour Foamaster
Edited 16-07-2013, 05:10 PM by AutoRaeChem.
AutoRaeChem
04-06-2020, 07:35 AM #4
AutoRaeChem
04-06-2020, 07:38 AM
we can get them
£59.40 + VAT & P&P
AutoRaeChem
04-06-2020, 07:38 AM #5
we can get them
£59.40 + VAT & P&P
04-06-2020, 09:20 AM
thanks rachel
04-06-2020, 09:20 AM #6
thanks rachel
09-08-2020, 05:55 AM
Hi Rachel , do you do replacement fittings for the foam lance ? I've got a carcher one that I bought from you a few years back and the fitment that goes onto the pressure washer is now leaking. It's spraying water all over the place now lol. If so can I order one please ?
09-08-2020, 05:55 AM #7
Views 1,062
07-05-2017, 03:38 AM
