JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Big Breaks
Big Breaks
Big Breaks
philip_98
09-07-2020, 03:50 AM
My new wheels are getting ordered at the end of the month after payday and im just worried that my standard discs will look S**T behind them.
Is it possible to just fit bigger discs to the standard break or will the calipers need changing as well? not wanting to go and fork out a fortune for a complete new set up when its only really needed for the aesthetics.
Cheers for any help
philip_98
09-07-2020, 03:50 AM #1
Cheers for any help
09-07-2020, 04:03 AM
If you fit bigger disc's you will need to chnage/relocate the calipers.
You can get FIG's brackets so you can use the standard calipers with supra TT disc's, still a large cost though
09-07-2020, 04:03 AM #2
09-07-2020, 04:05 AM
You can use the FIGS brackets which allow you to fit 323mm UK Supra discs with the stock calipers. You can only get them from the states though.
09-07-2020, 04:05 AM #3
09-07-2020, 04:10 AM
Bigger disks need bigger calipers. FIGS do an adapter to allow supra disks on an is200 and keep the OEM caliper. See sprinter for details.
09-07-2020, 04:10 AM #4
philip_98
09-07-2020, 04:14 AM
Oh well will wait and see how its looking when i get the wheels on then sort it out, cars going into the garage for the next 12 months anyway
philip_98
09-07-2020, 04:14 AM #5
09-07-2020, 04:24 AM
With stock discs:
[Image: IMG_0692.jpg]
With 323mm discs:
[Image: DSC002411.jpg]
09-07-2020, 04:24 AM #6
With stock discs:
With 323mm discs:
