JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Error codes P0135, P0300, P0302, P0303 and P0306
P.Lindblom
10-09-2020, 07:54 AM
A few weeks ago my IS200 got a CEL. I've got a code reader constantly plugged into my OBD-port, so I immediately checked the error code. It turned out to be P0135 - O2 Sensor Heater Circuit Bank 1 Sensor 1.
[Image: cnf8.png] [Image: d6ys.png]
I didn't panic, since it didn't really affect the engine performance, but i think the fuel consumption went up a bit.
My local spare parts store wanted £200 for a new O2 sensor, so I ordered one from Ebay and kept driving. The delivery time was around a week and I needed to use my car to get to work, so I just crossed my fingers and hoped nothing bad would happen.
A few days later I started my car to drive home from work and the CEL started flashing along with the TRC light. I read the following codes:
[Image: t77y.png]
Also, I could feel the car wasn't running on all six cylinders. I drove it home and let it sit until I got my new O2 sensor.
I'm not sure how old O2 sensor should look, but I've got a feeling they should be a little bit cleaner than this:
[Image: 5a9d.jpg]
I replaced the sensor, reset the ECU and started the car. It was still running on five cylinders, so I checked all the spark plugs. 1-5 looked fine, but number 6 was wet and smelled petrol. I cleaned it a bit and then swapped it with the number 5 one. After putting everything back together again I turned the key and the engine was as smooth as ever :w00t:
I just thought I'd post this in case someone else experiences the same thing in the future.
P.Lindblom
10-09-2020, 07:54 AM #1
[Image: t77y.png]
[Image: 5a9d.jpg]
10-09-2020, 09:39 AM
Glad to hear you sorted it mate!
10-09-2020, 09:39 AM #2
john wan
10-09-2020, 10:18 AM
Ha ha ha ive had sane stuff happening to me changed the o2 sensors that worked for a day or so then gradualy started again then cleaned plugs again that helped till eventually at the weekend I found track marks down the side of a plug only slight black lines about a hairs width where it had been arching out an causing problems miss fires an from the afr guage making the lambdas run funny to
john wan
10-09-2020, 10:18 AM #3
10-09-2020, 10:19 AM
Wonder if you've got an ignition coil on the way out?
10-09-2020, 10:19 AM #4
john wan
10-09-2020, 11:17 AM
Kinda what I was looking for
john wan
10-09-2020, 11:17 AM #5
P.Lindblom
10-09-2020, 11:31 AM
I had six unused ignition coils lying around, so I replaced them after I got the car running again. I've also ordered a set of new spark plugs, just in case.
P.Lindblom
10-09-2020, 11:31 AM #6
Views 1,488
14-01-2018, 05:51 AM
Last Post by is300_dino
Views 847
06-07-2016, 10:58 AM
Views 450
06-07-2016, 07:48 AM
Last Post by Davros
