JapCarForum Cars, Cars, Cars! Wheels & Tyres Different PCD'd wheels
17-09-2020, 02:36 PM
Ok guys. Got a question regarding wheels with a different pcd to standard.
Would a set of 18"x8 et35 with a 5x112 pcd fit the IS without much work???
Or what work if any would be needed to make them fit??
17-09-2020, 02:36 PM #1
17-09-2020, 03:12 PM
5 x 112 would fit quite fine using 'wobbly bolts', which let the cone part of the bolt sit in the correct position while still allowing the bolt to remain straight.
Most important thing is that you have the correct centre bore (60.1), that way all the bolts do is keep the wheel against the hub, rather than supporting it's weight/keeping it centralised.
17-09-2020, 03:12 PM #2
18-09-2020, 05:01 AM
Cheers for the info, centre bore I believe is bigger but Id be getting spigot rings to sort that out. If they will fit with just using wobbly bolts then that's spot on for me. Now to sort out my funds so I can source a set.
18-09-2020, 05:01 AM #3
Views 617
26-06-2023, 03:30 PM
Last Post by Is200kid
Replies 18
Views 1,186
11-06-2023, 09:56 PM
Last Post by Mr_Woods
Views 1,071
27-07-2021, 08:37 AM
Last Post by leesw20
Views 1,077
31-03-2020, 11:50 AM
Views 731
31-03-2020, 10:36 AM
Last Post by Colin G
Views 729
14-01-2020, 08:30 AM
Last Post by Manpanzee
Views 743
16-08-2019, 11:14 PM
Last Post by S555MRJ
Views 1,328
01-08-2019, 09:19 AM
Last Post by S
