JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! IS200 EFI fuse problem
Reinbou
21-10-2020, 11:53 AM
Few hours ago my car died out while driving. I tried to start and startermotor runs normally but the car wont start. Next I checked fuses and found that EFIConfused fuse was burned. I put a spare fuse to the socket but it burned instantly when I turned engine electricity on. To make sure I repeated it with new fuse but burned again. Everything else with quick check looks fine to me. No broken wiring or anything. Only thing was the missing droning sound from petrolpump.
Anyone who could know anything about this?? Only thing what came to my mind is that petrolpump is somehow broken or jammed and short circuiting ... Wiser opinions? Smile
Thanks!
Reinbou
21-10-2020, 11:53 AM #1
Thanks!
21-10-2020, 12:50 PM
Could be the pump shorted, or the EFI relay broken, you'd need to poke about with a meter to find out
21-10-2020, 12:50 PM #2
Reinbou
22-10-2020, 05:43 AM
Yes. After gym I have to go and tear down rear seat and unplug fuelpump. I also found something written about EFI relay problems. Hope that it won't pop fuses after unplugging fuelpump. It needs to be replaced anyway because I'm working alongside with boostingproject. Hoping that someone could conjure me new stonger conrods Big Grin
Reinbou
22-10-2020, 05:43 AM #3
Reinbou
22-10-2020, 10:25 AM
Problem solved. Pump shorted. After unplugging pumps connector fuse didn't pop. Also put cables straight to pins from other battery and nothing happen. Now searcing new more powerfull pump. Are there something I should know when installing different kind?? Or should they work straight?
Reinbou
22-10-2020, 10:25 AM #4
john wan
22-10-2020, 11:54 AM
They will work straight away might just need to fit the plug off the old one onto the new should come with instructions on how mine did
john wan
22-10-2020, 11:54 AM #5
22-10-2020, 01:06 PM
Think its a gss342 you need from walbro for a more powerful one
22-10-2020, 01:06 PM #6
john wan
22-10-2020, 01:14 PM
The right one is in my build thread matey
john wan
22-10-2020, 01:14 PM #7
Reinbou
03-11-2020, 08:18 AM
Pump wasn't shorted after all. Relay is also fine. It was faulty lambdawires that sometimes shorted cause exhaustpipe vibrating. Too many contacts with the ground cause low car and Japspeed catbacks improperly installed lambdasensor hole! Have to someday change sensorhole position when I have time. But new walbro 255 works fine Smile Little wrestling with installation cause it bigger pump but now its fitting okay. Now my car doesn't rev correctly to redline cause 310cc nozzles and no back lambda but those can be fixed in no time.
Reinbou
03-11-2020, 08:18 AM #8
03-11-2020, 10:28 AM
glad you solved it Smile
03-11-2020, 10:28 AM #9
john wan
03-11-2020, 10:45 AM
So what your saying is the lambda was moving about slightly in its hole an causing the lambda to not be grounded propperly? I pulled the signal wire out of bank2 and the cars not stutterd or run lean all week but ive had p0125 code pop up
john wan
03-11-2020, 10:45 AM #10
Views 1,500
21-03-2024, 04:36 PM
Views 779
19-02-2023, 01:37 PM
Views 1,993
15-02-2023, 12:16 AM
Last Post by cjoseph
Views 980
07-05-2022, 10:47 AM
Last Post by piman2k
Views 2,454
16-05-2021, 11:52 PM
Last Post by AARONMCCONNELL1
Views 1,075
20-03-2021, 09:49 AM
Last Post by Millo73
Views 800
16-03-2021, 11:12 PM
Views 4,438
15-04-2020, 10:52 AM
Views 531
08-02-2020, 07:34 AM
Last Post by Jaminglish
