JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Issues with sat nav
Issues with sat nav
Issues with sat nav
Fire_Fox_69
08-12-2020, 10:18 AM
Been having a bit of bother with the sat nav recently. Turn engine over and screen flicks up and normal green start up screen is displayed, but stays on for longer, then says check sat nav loading shelf. Have taken disc out given it a clean popped it back in, same thing happens again. Once driving about it starts working again normally. Was thinking it might be the screens ribbon which is faulty...Does any one have any ideas on how to rectify this problem? I'm heavily reliant on the sat nav for work, so need it sorting asap
Fire_Fox_69
08-12-2020, 10:18 AM #1
13-12-2020, 01:02 AM
the unit does come apart easily to check the cables on the screen
i would check the wiring plugs etc make sure no cables are snagged etc at both the brain and the screen
13-12-2020, 01:02 AM #2
Replies 18
Views 815
30-08-2018, 08:48 AM
Last Post by Kevpr
Views 753
30-01-2018, 11:13 AM
Last Post by karlp
