JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications SuperCharger Rebuild.
liquidlazer
09-12-2020, 07:35 PM
Hey guys do you all have any experience in replacing the 2 front rotor bearings on the chargers ?
Mines are gone and need some advice on repairing it.
I have the correct bearings just need to acquire the seals.
liquidlazer
09-12-2020, 07:35 PM #1
10-12-2020, 01:30 AM
Rob is your man for this
10-12-2020, 01:30 AM #2
rob
11-12-2020, 01:03 AM
Its a complicated job. You can get kits however.
You need access to measuring kit and aluminium tig welding gear a high pressure press 5-10000kg works, and do you know how to set the timing? You could index mark everything though.
The bearings set the end float of the rotors, once it goes the rotors can move backwards and they chew the casing scrapping the charger unit. It happened to me.
There was a danish lad here who took my old charger kit, I read he replaced the 2 front bearings at some stage.
AFAIK the seals are a unique non standard size.
rob
11-12-2020, 01:03 AM #3
liquidlazer
11-12-2020, 12:22 PM
Hey Rob. That's the exact thing with my charger. After removing the puller and cover. Upon inspection one of the gears had a forward and back movement play. The bearings are gone. Also the charger had no oil. Sad I assume because I'm using a bigger pulley on the charger for more boost the heat produced cause the oil to dry up thus destroying the front bearings. The front plate is also damage. Do you have any pics which can assist me in my rebuild ?
liquidlazer
11-12-2020, 12:22 PM #4
liquidlazer
11-12-2020, 12:34 PM
https://jonbondperformance.com/index.php...98hjkuc8b2
Anyone willing to do a repair on the front bearings. They sell the seals for the front bearings.
liquidlazer
11-12-2020, 12:34 PM #5
rob
12-12-2020, 04:17 AM
liquidlazer Hey Rob. That's the exact thing with my charger. After removing the puller and cover. Upon inspection one of the gears had a forward and back movement play. The bearings are gone. Also the charger had no oil. Sad I assume because I'm using a bigger pulley on the charger for more boost the heat produced cause the oil to dry up thus destroying the front bearings. The front plate is also damage. Do you have any pics which can assist me in my rebuild ?
Contact a guy with the member name daniel L or daniel N he replaced the bearings on my old charger.
rob
12-12-2020, 04:17 AM #6
Views 1,893
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 816
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 513
06-04-2023, 02:00 AM
Replies 24
Views 1,192
12-01-2023, 11:53 AM
Views 176
03-01-2023, 01:19 PM
Views 133
27-12-2022, 10:58 PM
Views 468
02-12-2022, 01:57 PM
Views 482
04-11-2022, 05:54 AM
Views 84
30-07-2022, 01:49 PM
