Eat My Dirt 250ml Ninja Cleaner - Concentrated Cycle - Motorcycle Cleaner
Eat My Dirt Ninja Cleaner
"The Ninja strikes, cleans, and disappears."
WHAT IS EAT MY DIRT NINJA CLEANER?
Eat My Dirt Ninja Cleaner is a strong, biodegradable cleaner for use on Cars, Bikes, Marine, House and Garage etc. At motorgeek, we particularly love it as a wheel cleaner. Where other wheel cleaners fail, Ninja Cleaner cuts through brake dust and road grime to clean wheels to an awesome shine.
Ninja Cleaner cleans oil, grease, and stains from numerous surfaces including metal, plastic, concrete, granite, fabrics, and painted surfaces.
EMD Ninja Cleaner is pH neutral. That means it's neither acid nor alkaline. Don’t be fooled by other cleaners that claim to be acid free, they are often alkaline based which is equally as corrosive but the word alkaline appears less offensive. Eat My Dirt Ninja Cleaner is a non-toxic, pH neutral cleaner that is safe for humans and the environment. EMD does not contain dangerous, caustic chemicals and will not damage metal or plastic parts.
Ninja Cleaner comes in both 1 litre and 250ml sizes, which makes both cost effective and good value for money as 1 litre makes up to 40 litres of biodegradable wash. It can be used at different dilution rates depending on the state of the object being cleaned.
It is best used diluted down with water, allowing it to be worked up into a lather. How much water you add depends on the level of grease and dirt you are cleaning. Here at Motorgeek we have used it from a neat spray up as far as 40 to 1.
Dilution rates can be found on the side of the bottle together with specific cleaning instructions.
Cars
Eat My Dirt Ninja Cleaner is a brilliant all round cleaner for cars and caravans. It works great as a wheel cleaner but can be used on bodywork, glass and mirrors, as well as the dash and interior trim.
Bikes
Eat My Dirt Ninja Cleaner is ideal for cleaning motorbikes and cycles. Its pH neutral formula means that it is safe to use on disc brakes, and won’t remove stickers. It also removes dirt and oil from chain sets brilliantly when used with a soft fine-bristled brush or microfibre cloth.
Quick clean after ride: Rinse bike, dilute a 10 to 1 solution in a bucket and use a soft brush. Apply EMD to bike frame with a bit of elbow grease, run brush around wheels and tyre walls. Brush rear triangle, chain set and cassette, and rinse off. The softer the brush the better.
Detailed Clean: Rinse bike, brush thoroughly with eat my dirt using a 10 to 1 dilution. Turn bike upside-down, remove wheels, remove chain and soak in solution of same dilution. Brush frame, brakes, inside forks and stays, gear and chain-set and cassette. Brush chain if it is not in a bath. Rinse and rebuild. Lubricate as necessary.
Marine
Detailed Clean: Start with a 10 to 1 dilution mixed in a bucket, using a soft brush, work the solution up into a lather and clean in circular motions. Rinse off and wipe as required. Increase or decrease the dilution next time as you feel necessary.
House
Great on hard floors, shower trays and glass, tiles, granite, rubber seals of washing machines, white goods, radiators and pipes, electrical cables, and other hard plastic surfaces.
Garages and Workshop.
Great for showroom floors, parts washers and removing engineering marking blue etc.
Price delivered
250ml @ £6.99
1L @ £14.49
Please send payments to paypal on [email protected]
