JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications T piece
T piece
T piece
Pages (3): 1 2 3 Next
196
01-03-2021, 02:11 PM
Can anyone help. i am running a bypass pipe and i need a T piece for it. i wont be running the normal bypass pipe but the T piece is still same i believe. the pipes are 2.5 inch and the bypass from the mini i believe is 38mm but i cant seem to find one. what has others done?
lexusdaydreaming
01-03-2021, 02:11 PM #1
196
01-03-2021, 10:36 PM
this is for the bypass on lexus is 200 supercharger.
lexusdaydreaming
01-03-2021, 10:36 PM #2
02-03-2021, 01:31 AM
I'm a bit confused what you need mate, you go a pic?
02-03-2021, 01:31 AM #3
02-03-2021, 03:27 AM
in a normal is200 supercharged there is a bypass valve and pipe. and the pipe goes into a Tpiece underthe charger i need a t piece like that.
lexusdaydreaming
02-03-2021, 03:27 AM #4
02-03-2021, 04:24 AM
Ah right, can you not just get a pipe welded onto the outlet piping between the charger and intercooler? Probably your best bet.
02-03-2021, 04:24 AM #5
02-03-2021, 04:32 AM
i was wondering what others have done. either silicon and where from. last resort i will get a piece made up but i thought there is a exact piece i could buy out there.
lexusdaydreaming
02-03-2021, 04:32 AM #6
02-03-2021, 04:37 AM
Other have used blow off valves or other homemade parts.
You could get a 63mm (2.5inch) silicone t piece with a standard 25mm spout, then just reduce the 38mm bypass outlet to 25mm with silcone reducers between
02-03-2021, 04:37 AM #7
02-03-2021, 04:53 AM
i have blow off valve too but have been told i need bypass too. i will be using a vacuum operated bypass. will reducing it to 25mm be ok with the air being squashed at that end.
lexusdaydreaming
02-03-2021, 04:53 AM #8
02-03-2021, 06:10 AM
Im in the same boat mate it must be said. Was trying to work out what to do with that part
02-03-2021, 06:10 AM #9
phaebo
02-03-2021, 06:49 AM
There are also silicone t hoses on ebay with bigger spout diameters. For example 30. But they are harder to find then with 25 mm spout.
phaebo
02-03-2021, 06:49 AM #10
