JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications IS300 Manual Conversion
bounty`
03-03-2021, 11:43 PM
So I'm looking at a few different options for more power this year/next.
The latest of which is an IS300 with some choice mods.
So, to do a manual conversion Im guessing it's a case of running either an r154 6 speed Supra box, or a w58, with either an adapter plate or custom/modified bell housing?
[Image: OJCSig.jpg]
bounty`
03-03-2021, 11:43 PM #1
[Image: OJCSig.jpg]
04-03-2021, 12:26 AM
The r154 is a 5 speed. You will need a remote shift r154 from the manual soarer or the mk4 supra. The 6 speed will fit but will cost you daft money. Have a look for the v160 or v161. W58 should fit, not sure where the shifter will be though. Whatever you do, a prop needs to be made. I think the r154 and v160 will be bolt on, as they are both from a jz engine.
04-03-2021, 12:26 AM #2
04-03-2021, 12:27 AM
I think the manual is300 in the states was a w55 box, not sure about the details though.
04-03-2021, 12:27 AM #3
bounty`
04-03-2021, 12:29 AM
So in theory, an R154 will bolt straight on with no mods? What about mounts?
[Image: OJCSig.jpg]
bounty`
04-03-2021, 12:29 AM #4
[Image: OJCSig.jpg]
04-03-2021, 12:36 AM
If you had a remote shift, prop and clutch. You'd need to mess with the ECU to trick it into thinking it still had the auto gearbox. Mounts, no idea.
04-03-2021, 12:36 AM #5
bounty`
04-03-2021, 01:35 AM
Remote shift is a new one on me?
[Image: OJCSig.jpg]
bounty`
04-03-2021, 01:35 AM #6
[Image: OJCSig.jpg]
04-03-2021, 03:32 AM
There are two types of r154, one with remote shifter position and one without. You need the one with a remote shift. Basically the gear stick is further back.
04-03-2021, 03:32 AM #7
Views 973
29-08-2019, 10:16 PM
Views 1,507
23-08-2018, 10:41 AM
Last Post by Talisker
Views 490
28-07-2018, 03:56 AM
Replies 22
Views 1,886
29-01-2018, 12:41 PM
Last Post by DK_KARL
Views 834
01-02-2017, 01:26 AM
