JapCarForum Cars, Cars, Cars! General Car Maintenance only getting hot air
Pages (3): 1 2 3 Next
08-03-2021, 04:22 AM
Hi folks. Just wondering if anyone can help with this.
My heater in the lexus will only blow hot air out of the vents in the dash.
Can't get air out of the ones for your feet or front windows.
Any ideas how to fix this ?
Oh and don't know if this is relevant or not but also the buzzer that tells you that you've left on your lights also dose not work.
These things are pisssing me off !!!!!
08-03-2021, 04:22 AM #1
08-03-2021, 06:57 AM
Now I can get cold air to. But still nothing from from the windows vents !!!
08-03-2021, 06:57 AM #2
08-03-2021, 10:05 AM
Let me have a nosey round some diagrams see if i can see a common fuse or something
08-03-2021, 10:05 AM #3
08-03-2021, 10:41 AM
Also sometimes my dead locks don't work and the indicators that Flash when you lock it sometimes don't work
08-03-2021, 10:41 AM #4
08-03-2021, 01:13 PM
Hmm I'll have a look mate
08-03-2021, 01:13 PM #5
Tosh21
12-03-2021, 08:26 AM
found the solution yet cheif? Mine is blowing hot as f*** all the time, gets a bit annoying with weather warming up a bit!
Tosh21
12-03-2021, 08:26 AM #6
12-03-2021, 09:19 AM
I've had a look.
Have you any fuses blown at the moment?
Anything else not working or fiddled with recently?
12-03-2021, 09:19 AM #7
I've had a look.
12-03-2021, 09:41 AM
I've pulled ever fuse out to check them. Well just the normal thin ones.
And they are all Ok. Like I said buzzer for the lights.and sometimes the dead locks don't work and the India don't Flash when locking the car
12-03-2021, 09:41 AM #8
12-03-2021, 10:52 AM
Hmm, the locks thing can be turned on or off, I'll try and figure out how to test.
Not sure about the buzzer
12-03-2021, 10:52 AM #9
lex2oos
12-03-2021, 09:27 PM
if there is a problem with inside temperature sensor (if it is disconnected) HVAC only works in two ways - it will blow hot air unless temperature is set to maximum cold, then it will blow cold air...
lex2oos
12-03-2021, 09:27 PM #10
