JapCarForum Car Manufacturers Lexus/Toyota problem...need help
problem...need help
problem...need help
Pages (4): 1 2 3 4 Next
daveo
20-03-2021, 12:55 AM
rite lads have an issue with the car. i supercharged my is200 lately.
wired in a patrick black box
used a 140mm pulley on the water pump
dw 300 series fuel pump
fuel pressure reg
used a dumpvalve as a blow off and blocked up the bypass
when cold she runs the finest. when she warms up the front mount gets seriously hot and she dies the minute i sink the boot.
anyone know what the problem might be?? if ye add me on facebook...."lexibreak" ye will see pics of my build.
all help appreciated as im at my witts end with it !! Smile
daveo
20-03-2021, 12:55 AM #1
fuel pressure reg
20-03-2021, 01:17 AM
Why did u block up bypass? Surely without that she will run to hot. Why not refit the bypass and bov see how that goes
20-03-2021, 01:17 AM #2
daveo
20-03-2021, 01:51 AM
i blocked the bypass as im using the dumpvalve option instead pat.
daveo
20-03-2021, 01:51 AM #3
20-03-2021, 04:22 AM
Ive been yold by a few people to run both esp on a kit with larger pulley. That may be the cause
20-03-2021, 04:22 AM #4
20-03-2021, 04:57 AM
the dumpvalve doesnt allow air to pass around the charger when your idling/cruising
20-03-2021, 04:57 AM #5
daveo
20-03-2021, 05:06 AM
so what do you reckon i should do fella ??
daveo
20-03-2021, 05:06 AM #6
20-03-2021, 05:10 AM
Refit the bypass
20-03-2021, 05:10 AM #7
Refit the bypass
20-03-2021, 05:11 AM
Did u just blank off the bypass or did u never have one
20-03-2021, 05:11 AM #8
daveo
20-03-2021, 05:18 AM
i never had one. we have 2 other supercharged lexus here. both running perfectly, neither of them have a bypass nor have they a patrick blackbox !!!!
daveo
20-03-2021, 05:18 AM #9
20-03-2021, 05:20 AM
Hmmm thats very odd then
20-03-2021, 05:20 AM #10
Views 382
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Views 212
01-02-2021, 01:25 AM
