JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Supercharger on an auto ??
Andysaltezza
14-04-2022, 04:25 PM
Hi everyone just wondered if it's possible to fit the supercharger to an auto as been reading up on this but everyone seems to talk about a uprating the clutch and flywheel too,so if it is possible would the auto box be up to the task ??
Andysaltezza
14-04-2022, 04:25 PM #1
14-04-2022, 04:28 PM
you don't need to upgrade the clutch and flywheel on the manual is200 to cope with a supercharger, it just makes your acceleration a bit quicker (if you get a lighter flywheel). The auto will be fine unless you're running something mad.
Edited 26-05-2014, 08:14 PM by el_bandido.
14-04-2022, 04:28 PM #2
Andysaltezza
14-04-2022, 05:19 PM
Thanks for that,I'm guessing the fitting of the supercharger is the same as you would on a manual ?
Andysaltezza
14-04-2022, 05:19 PM #3
14-04-2022, 05:21 PM
Almost exactly yes!
14-04-2022, 05:21 PM #4
Almost exactly yes!
Andysaltezza
14-04-2022, 05:24 PM
Thanks guys, just wondering wether to do it Smile
Andysaltezza
14-04-2022, 05:24 PM #5
14-04-2022, 06:31 PM
if you want an auto with more grunt, use the money you'd sink into a supercharged IS to buy an IS300. Then when you get bored of that, you can buy a lot of off the shelf 2JZ mods.
14-04-2022, 06:31 PM #6
Almost Finished
14-04-2022, 09:32 PM
Do not supercharge your is200 auto . I did and it shagged my auto box :thumbdown:
Almost Finished
14-04-2022, 09:32 PM #7
15-04-2022, 03:26 AM
What year was your car Dave? There is a turbo IS200 auto knocking about down south that's running about 280-300 with the bog standard auto box.
15-04-2022, 03:26 AM #8
Almost Finished
15-04-2022, 07:12 AM
el_bandido What year was your car Dave? There is a turbo IS200 auto knocking about down south that's running about 280-300 with the bog standard auto box.
My auto box was running for three weeks , how long has this car been running , or is it on axle stands broken? Bloke in the pub said his brother was running 500 on auto box!!! so it must ok .
Edited 27-05-2014, 11:26 AM by Almost Finished.
Almost Finished
15-04-2022, 07:12 AM #9
reganlives
15-04-2022, 08:29 AM
Interesting to hear about the auto box! Do you think it was possibly on its way out already?
As for supercharging an auto, you need to modify the mount for the charger as there's oil lines running along side of the engine. Me and stav found out the hard way and had to chop my mount.
Talking about my charger, Stav will have to pop round to yours again sometime soon to finally finish the charger! I just need to get my decay manifold now and get the injectors cleaned then we'all be ready to finish the install
reganlives
15-04-2022, 08:29 AM #10
Views 2,959
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 1,347
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 762
05-04-2024, 07:48 AM
Replies 24
Views 2,470
12-01-2024, 05:42 PM
Views 481
03-01-2024, 07:08 PM
Views 321
28-12-2023, 04:46 AM
Views 692
02-12-2023, 07:46 PM
Views 726
04-11-2023, 11:43 AM
Views 225
30-07-2023, 07:38 PM
