Lambda sensor.
Lambda sensor.
Hi I need help I am in middle of replacing rear exhaust lambda sensor and I can't find where it plugs in to it goes in to the body of car the wire I mean and I can't follow it back. Do I have to cut and rewire rather than use the plug?
you should remove the plastic cover were the wire goes into and behind there is the plug
I found it it is located under passenger seat put seat forward as far as it can go and pull carpet back I had to cut a little into carpet all good thsnks
Now am geting a new code p0125 need help. Done a lot if looking around not had any luck.
you could of just removed the seat its only 4 bolts. i had to replace my lambda a while back so took the seat out also meant i could clean the carpets that dont normally get seen
Yea but my mood was low and it was raining it wasn't bad and was faster than taking seat out. But now am stuck with this p0125 code it wasn't there untill I put new sensors in I reset ECU.
PO125 means 'aggggggghhhhhhh there's a hole in my carpet - I'm a Lexus! Too posh for religious carpets'
Lol it's more of a slit but any help on the code would be great.
Well that code does mean a bad sensor so is it 100% the correct one or is it a duff one
It is the denzo one and genuine new. I have an idea as I put a right angle adaptor on am have to drill body work and then put sensor back in with out adaptor. I have full stainless exhaust with de cat would that through up codes? And with charger on switch but piggyback is constant maybe that I dunno.
