JapCarForum Club Sponsor Auto Rae Chem Valet Pro Dragons Breath 1L 1 Litre - Iron Contamination Remover
AutoRaeChem
28-04-2021, 03:21 AM
Valetpro Dragons Breath – Iron Decontaminate Remover x
Valetpro’s Dragons Breath comes pre-diluted to the correct strength for safe exterior use. In all cases, wash and rinse the surfaces you are going to treat in the normal way and allow to dry.
Next, spray on liberally. As any iron contaminants dissolve into solution, the initially colourless liquid will gradually turn purple over a period of 1-2 minutes.
Although Dragons Breath is essentially a touch less cleaner, you can agitate it with either a microfibre towel or a brush. After 1-2 minutes, or once the dark purple solution has dried fully, thoroughly rinse the surfaces you have treated with a strong stream of water. If you let the solution dry fully, you may need to use a stronger jet of water from a pressure washer to remove the hardened film.
Dissolve brake dust and other iron-rich contaminants upon contact,
Please wash any brushed or microfibre towels out after use, DO-NOT place any microfibres in the washing machine for wash, if been in contact with Dragons Breath.
This product has a very strong odour and should be used in a well-ventilated area. Keep out the reach of children.
[Image: dragonsbreath500ml_zpsc1eef85d.jpg]
PRICE DELIVERED @ £10.49
Please send payment to paypal on cardazzle@me.com
AutoRaeChem
28-04-2021, 03:21 AM #1
Views 130
20-06-2021, 04:23 AM
Last Post by AutoRaeChem
Views 236
29-06-2018, 04:19 AM
Views 248
15-02-2018, 06:59 AM
Views 347
02-06-2017, 06:36 AM
