JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Air con repair?
Air con repair?
Air con repair?
07-08-2016, 08:29 AM
How hard will this set of pipes be to change:
[Image: airconpipecloseup.jpg]
I have a leak on the one that goes to the back of the engine bay - which is why my air con doesn't work.
07-08-2016, 08:29 AM #1
07-08-2016, 08:45 AM
If I'm reading the parts diagram correctly, then the price of that pipe looks to be just under £100. Which to be honest is less than I was expecting.
Don't know if you have to take out other stuff to replace that pipe, or whether it can perhaps even be repaired (do you know exactly where the leak is ?).
Obviously then you'll need your aircon re-gassing.
07-08-2016, 08:45 AM #2
07-08-2016, 08:46 AM
could be a fair bit of work.
custom made its a lot of small bends, you'd have to see how much it is from Lexus, then maybe change it yourself and then pay to fill it up?
07-08-2016, 08:46 AM #3
07-08-2016, 08:47 AM
The re-gassing showed up the leak and apparently you can't repair the pipe?
For that cost I may as well let Lexus do the job one day - if they will work on my car that is:Chair:
07-08-2016, 08:47 AM #4
07-08-2016, 10:13 AM
I bet the price will go UP, even though this part of the car is un-modded:thumbdown:
07-08-2016, 10:13 AM #5
07-08-2016, 10:17 AM
2tongues The re-gassing showed up the leak and apparently you can't repair the pipe?
Why not , did you ask them why it could not be repaired ?????
07-08-2016, 10:17 AM #6
07-08-2016, 10:31 AM
No TGT were dealing with it??
May try a local guy for a 2nd opinion.
07-08-2016, 10:31 AM #7
Views 1,675
20-01-2019, 01:03 PM
