JapCarForum Car Manufacturers Toyota altezza owners!!! i need help
Tosh21
11-06-2021, 09:50 AM
Just done a head rebuild and bolted it all down it's good so far. Cams bolted down then when I put the pulleys on the inlet marks are 2 teeth too advanced.
Does anyone know where the locating Dowell on the cam points when cylinder 1 is tdc?
I lines up the exhaust Dowell with the timing Mark and it gets back there every time and did the same with the inlet but the inlet knock over just as I reach the mark on the pulley. I'm not sure if it is meant to be under tension from a spring at tdc or not as when I took it off it never moved
Tosh21
11-06-2021, 09:50 AM #1
11-06-2021, 10:04 AM
Got any pics mate?
11-06-2021, 10:04 AM #2
Got any pics mate?
Tosh21
11-06-2021, 02:09 PM
No I'll take some tomorrow. Bassically there is a dowel on the cam and the pulley has a keyway cut into it so you can time the cam using the mark on the pulley.
I took the pulleys apart by accident hence the MASSIVE drama this has turned into.
If I knew where the dowels pointed at TDC I could then time it by setting the dowels and rebuilding the pulley to suit as there was no definate way of knowing the pulleys were rebuilt in the right orientation.
Tosh21
11-06-2021, 02:09 PM #3
john wan
11-06-2021, 08:35 PM
Have you asked on tezza world? Theres a guy on driftworks thats had one as a drift car but for life of me I cant remember his name at the mo
john wan
11-06-2021, 08:35 PM #4
Tosh21
11-06-2021, 09:13 PM
yea put one up there too. PM'd him also but no reply yet
Tosh21
11-06-2021, 09:13 PM #5
11-06-2021, 11:24 PM
The setup sound similar to the 1ggte setup, have you got adjustable pullys on?
the 1ggte pulleys are actually identical to the 3sge ones just fitted the other way round so if you need some standard ones i should have some spare.
11-06-2021, 11:24 PM #6
Tosh21
12-06-2021, 12:38 AM
No just the standard altezza ones but I accidentally opened them and there are some marking for rebuilding them but they aren't obvious it's more an assumption so they could be oriented wrong hence my 2 tooth advance. I will rebuild it again incase I missed something.
How do you mean fit other way round? Are you sure they are the same? I've never heard that
Tosh21
12-06-2021, 12:38 AM #7
12-06-2021, 04:55 AM
The pully on the 3sge is the same part number as the 1ggte. Just flipped over
12-06-2021, 04:55 AM #8
12-06-2021, 04:57 AM
Just checked and it's the 3sgte they are the same as. The 3sge had vvti or something on it?
12-06-2021, 04:57 AM #9
Tosh21
12-06-2021, 09:08 AM
Yea the ge is very similar but tuned a lot more. Has dual vvti unlike the gte which is only inlet. It's alright I think I've got it. Inlet pulley has never been apart so took it apart to compare with exhaust and the keyway lines up with the mark on the pulley so I just need to hold it timed and put the belt on. Must have got lucky before when I took it off and it didn't spin. I'm just going to try it and hope for the best
Tosh21
12-06-2021, 09:08 AM #10
Views 205
01-10-2022, 01:40 PM
Last Post by egis200
Views 257
21-04-2022, 03:10 AM
Views 348
30-06-2020, 03:16 AM
Last Post by Merlin
Views 278
27-06-2019, 09:58 AM
