JapCarForum Car Manufacturers Lexus/Toyota Headlight Symbol
Headlight Symbol
Headlight Symbol
JeffMcC
28-06-2022, 03:23 PM
Started my car today after finishing work and my Headlight adjustment light stayed on after the car started. I've checked all my bulbs (all working). My headlights are auto self levelling, anyone had this issue? and how do I fix it?
.jpg
JeffMcC
28-06-2022, 03:23 PM #1
.jpg
28-06-2022, 03:39 PM
Are you sure you've got self levelling headlights? These weren't included as standard on the 200, I think it was an option on the limited edition. You might just have a knackered adjuster, have you had a look to see if either of them have ceased?
28-06-2022, 03:39 PM #2
mattlaw
28-06-2022, 03:41 PM
Check the height sensors arnt seized, also take them off the car and remove the back plate and check for corrosion, there's 2, nsr and nsf
mattlaw
28-06-2022, 03:41 PM #3
JeffMcC
28-06-2022, 05:03 PM
el_ Yes mate mine is the Ltd, Mat they work when I went in this morning and on the way home I didn't need to turn my lights on, but the dash light came on.
JeffMcC
28-06-2022, 05:03 PM #4
mattlaw
28-06-2022, 06:01 PM
If they're set to auto, they will automatically do a self level check when you turn the ignition on, the lights will work fine, just the leveling won't work
mattlaw
28-06-2022, 06:01 PM #5
Views 389
14-08-2022, 02:29 PM
Last Post by Predator
