JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! Lexus diff final drive
Kirsty19
01-09-2021, 01:09 PM
Hi all,
Wondering if anyone can help.
My mechanic thinks that my manual IS200 might have had an auto diff fitted at some point.
His reason for this is because at 70mph the car is revving at 3k - is this about right for a manual? Or might he be right?
Any help would be great! Smile
Kirsty19
01-09-2021, 01:09 PM #1
Hi all,
02-09-2021, 08:53 AM
The is200's are terribly high on revs on the motorway mate
02-09-2021, 08:53 AM #2
Kirsty19
02-09-2021, 09:42 AM
That's what I hoped someone would say. Thanks Smile
Kirsty19
02-09-2021, 09:42 AM #3
03-09-2021, 12:41 AM
The auto diff is a 4.3 and the manual sport diff is 4.1. You will be doing nearly 4k rpm at 85, so 3k at 70 sounds right with the manual diff.
03-09-2021, 12:41 AM #4
phaebo
03-09-2021, 09:09 AM
makes me wonder. What will happen when you put the auto diff to a manual is200?
Will that make the gears longer?
The is200 with supercharger is really asking for some longer gears.
I know that the speedometer will tell you the wrong speed but maybe you can get higher topspeed and have longer gears.
phaebo
03-09-2021, 09:09 AM #5
jeorje_2000
18-11-2021, 10:59 AM
you will obtain exactly the opposite with the auto diff you will make the gears shorter, you can put bigger tyres(diameter) on the rear wheels and you will obtain some gaines but you will reduce the acceleration a litle
jeorje_2000
18-11-2021, 10:59 AM #6
jeorje_2000
18-11-2021, 11:03 AM
the best solution it is to modify the 6 gear only with better gear ratio, but you need to open the gear box and find coppatible gear but with different ratio.
In this way you preserve the acceleration in al the gears except 6 gear who will be for crousing and better economy.
jeorje_2000
18-11-2021, 11:03 AM #7
18-11-2021, 11:45 AM
Use an S15 6 speed. Same gearbox designation as the IS200, I'd just find one of those gearboxes and see if it bolts on to the IS200. That will leave you doing about 3700rpm at 85 on the motorway, about 8% fewer revs. 1st gear is also slightly less aggressive, but there isn't much in it between the other 4.
You could do a supra rear end swap, there are some much lower diff ratios available but it will leave the car a bit wide; you will also start running into problems with the speedo giving you an incorrect reading. I reckon a diff swap is definitely the way to go though, you can keep your normal 6 speed and make all 6 gears longer in one go. Either way will cost you money.
18-11-2021, 11:45 AM #8
20-11-2021, 09:09 AM
I've done some digging and apparently some of the 4-runner diffs are the same size as the IS300 diffs, which might mean you can get a 3.071 ratio with an IS300 rear end and 4-runner ring/pinion. Could be the closest thing to a bolt in solution, but I've no idea for certain whether the 4-runner diff will actually fit. They are both toyota 8" diffs from the same series (I think).
Edited 01-01-2015, 06:43 PM by el_bandido.
20-11-2021, 09:09 AM #9
jeorje_2000
20-11-2021, 11:59 AM
el_bandido I've done some digging and apparently some of the 4-runner diffs are the same size as the IS300 diffs, which might mean you can get a 3.071 ratio with an IS300 rear end and 4-runner ring/pinion. Could be the closest thing to a bolt in solution, but I've no idea for certain whether the 4-runner diff will actually fit. They are both toyota 8" diffs from the same series (I think).
if the smal pinion is not pair with the big pinion you will have a lot of noise like a big old truck, i have tried this combination on a opel rekord and it is very noisy.
jeorje_2000
20-11-2021, 11:59 AM #10
Views 2,435
16-05-2021, 11:52 PM
Last Post by AARONMCCONNELL1
Views 1,070
20-03-2021, 09:49 AM
Last Post by Millo73
Views 795
16-03-2021, 11:12 PM
