JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Help needed sunroof closure
Millo73
10-10-2021, 10:19 AM
I am trying to install an aftermarket sunroof closure kit to work with the standard remote
The kit I have states it can do 2 windows and sunroof
But I only want sunroof to work
Any help would be great
.jpg
MeisterR low and hks silent is how to ride
Millo73
10-10-2021, 10:19 AM #1
.jpg
10-10-2021, 11:02 AM
What wiring have you figured out so far?
10-10-2021, 11:02 AM #2
Millo73
10-10-2021, 11:09 AM
I have the red (12v) sorted the White Acc black (neg)
I think I've sorted the 2 brown cables on the lock system
Main problem is the purple wire (sunroof)
Millo73
10-10-2021, 11:09 AM #3
10-10-2021, 11:21 AM
With that system it'll only close either on slide or tilt. Not both.
You need to run the wire up the a pillar (watch for airbags if you have them) then to the blue/red stripe for the slide, or red/white stripe for close on tilt.
The wires are behind the switch itself on the roof.
10-10-2021, 11:21 AM #4
Millo73
10-10-2021, 11:22 AM
Cheers mate could I split the cable to both?
Or is there another way altogether of doing it?
Millo73
10-10-2021, 11:22 AM #5
10-10-2021, 12:28 PM
No because if you send signal to both at the same time it will just do nothing, to work the sunroof unit needs to send a signal to lower for 2 seconds, then stop, then send the signal to slide close for about 5 seconds.
10-10-2021, 12:28 PM #6
Millo73
10-10-2021, 12:31 PM
Thanks for your help and advice it's just that I've heard of people having auto sunroof closure on is200 but can't find the I go to wire it up
Millo73
10-10-2021, 12:31 PM #7
10-10-2021, 12:54 PM
I have it on mine. Pro le x used to sell a kit made by a member on here called geoffers but that was years ago and not sure where the kits are these days. Prob on owners cars and they don't realise.
I have one on mine it's awesome.
You could make one with a timer and counter chip but you'll need some electrical knowledge for that.
10-10-2021, 12:54 PM #8
Millo73
10-10-2021, 12:55 PM
Cheers but I'm no good at that sort of stuff
Millo73
10-10-2021, 12:55 PM #9
Views 680
02-12-2020, 01:19 PM
Views 884
21-04-2018, 04:32 PM
Last Post by aaronabbott
Views 624
13-04-2018, 01:18 PM
Replies 22
Views 1,775
26-02-2018, 12:47 AM
Last Post by jimxms
