JapCarForum Cars, Cars, Cars! General Car Maintenance yet more problems with the scooby :(
Pages (7): 1 2 3 4 57 Next
bambam
09-11-2021, 08:04 AM
Well here goes.... when i got my car 3 weeks ago all was good and boosty, now the car doesent seem to pick up until around 4500 rmp and even then it aint much to brag about, ive just had overheating issues wich turned out to be the thermostat and a blocked return pipe, however the previous owner has put the fans on a constant live so the car doesent get hot enuf for the thermostat to open, anyway it did go flat now and agean before that but the boost problem seemd to come after all that.... anyone got any ideas?? Cheers
bambam
09-11-2021, 08:04 AM #1
09-11-2021, 08:40 AM
I'd check for a boost leak mate
09-11-2021, 08:40 AM #2
bambam
09-11-2021, 08:44 AM
Yeah i thort that mate, just with it coming on with the overheating i thort maybe the turbo overheated and fryed some how, it does have a manual boost controller plumbed in under the engine wich has very soft pipes, do ya think they could be collapsing under pressure?
bambam
09-11-2021, 08:44 AM #3
09-11-2021, 10:15 AM
It's likely, but if it's taking a while to come on boost it might be a leak on the pipework though, as that been off to fix the water problems?
09-11-2021, 10:15 AM #4
bambam
09-11-2021, 10:23 AM
The water feed pipe to the turbo from the water tank was took off and checked for blockages wich was fine and at the top of the turbo and pipework so nothing else had to be removed, the rest of it was at the front of the engine, ill just pull it apart at the weekend and see if theres any obvious holes or splits in any pipe, this is my first turbo car so its all alien to me but i guess thats half the fun in having a new car is gettin to no it.
bambam
09-11-2021, 10:23 AM #5
john wan
10-11-2021, 10:40 AM
Do you have a boost gauge? I'd aim for a boost leak to do you have a induction kit? The afm can get dirty and cause problems I've had scoops for years mate awesome cars
john wan
10-11-2021, 10:40 AM #6
bambam
10-11-2021, 10:45 AM
Yes i have a boost gauge mate, seems wierd to me when the car is off it sits at 0 and when the car is on it sits at the bottom, when i got the car i was told it was set up to rum 1.1 bar and on the gauge its showing half of that, and yes it has a pipercross cone filter.
bambam
10-11-2021, 10:45 AM #7
10-11-2021, 10:54 AM
Yeah it should drop low on idle as the car pulls a vacuum.
10-11-2021, 10:54 AM #8
bambam
10-11-2021, 10:56 AM
Cool so the reading is accurate then so im only getting half boost
bambam
10-11-2021, 10:56 AM #9
john wan
I'd say boost leak did you say it has a manual boost controller ? If yes have you been playing with it?
I'd don't get your explanation of the boost gauge mate.
Now with the piper cross filter (good choice they sound awesome on scoobys ) they do get the afm a bit coked up with poop so to clean them you need some carbon cleaner and some cotton wool ear buds spray the cleaner on the buds and stroke the blade on the afm gently it helps to keep them running right
john wan
10-11-2021, 10:56 AM #10
Views 1,448
21-04-2019, 01:15 AM
Views 436
07-03-2019, 05:02 AM
Views 727
17-07-2018, 03:14 PM
Last Post by purple samurai
Views 844
13-07-2018, 04:36 AM
Last Post by CherylTDI
Views 470
30-08-2016, 04:12 AM
