JapCarForum Club Sponsor Auto Rae Chem Poorboys Clay Lube & Clay Towel
AutoRaeChem
30-03-2022, 02:21 AM
AUTO RAE-CHEM Medium Grade Detailing Clay Towel 30cm x 30cm
Very quick and easy to use
Removes bodywork contaminants and overspray
Removes contaminants and overspray quicker and easier than finer grades
If dropped wash off in bucket of soapy shampoo
More durable than a traditional clay bar, lasting up to 5x longer
More Information
A quick and effortless detailing system that achieves professional showroom perfect shine results using advanced rubber polymer technology. This is a process which gives the same effect as Clay Bars as used in professional body shops. The Clay Towel is safe and easy to use, removing paint overspray, water spots, fresh tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, mouldings and plastic.
The Clay Towel can be cleaned and re-used by simply rinsing off the accumulated contaminants with water. The design of the Clay Towel surface allows for an effortless easy gliding action over the surface when used with appropriate detail solutions such Valetpro Citrus Bling or our own AUTO RAE-CHEM Final Touch. If neither of these is available water can also be used however results will not be as good.
To wash, simply rinse in water and hang to dry. Do not tumble dry!
Poorboys Clay Lube 473ml (16oz)
Poorboys Clay Lube is a super slippery lubricant designed to provide the perfect amount of lubrication for clay bars and clay bar alternatives, like the clay mitts and clay cloths. Clay Lube reduces the risk of clay media from scratching the paint because it creates a barrier slick enough that clay bars and clay bar towels effortlessly glide across the surface, picking up contaminants to create a smooth finish ready for waxing!
Poorboy’s World Clay Lube can be used in sun or shade! If you don’t have a garage, or if you’re a professional detailer, Poorboy’s World Clay Lube will help speed up the process of claying your vehicle because you don’t have to worry about the product staining the paint. Of course, you still want to use common sense when working in direct sunlight, but Poorboy’s World Clay Lube makes it a lot easier!
Don’t waste time washing your vehicle after claying it! With Poorboy’s World Clay Lube, all you have to do is wipe away to a clean, polish-ready surface.
Poorboy’s World Clay Lube has been tested and approved for use with all clay bars and clay bar alternative
[Image: CLAY%20TOWEL%20MEDIUM%20_zpsx2dacv4x.jpg]
[Image: POORBOYS%20CLAY%20LUBE_zpseglz25eh.jpg]
Price Posted @ £19.95
Please send payment to paypal on [email protected]
AutoRaeChem
30-03-2022, 02:21 AM #1
More Information
Views 248
09-04-2024, 02:07 PM
Last Post by AutoRaeChem
Views 210
11-07-2022, 12:04 PM
Views 268
11-01-2022, 12:10 PM
Views 113
28-10-2021, 02:37 AM
Views 454
15-07-2021, 09:44 AM
Last Post by purplewitch
Views 130
20-06-2021, 04:23 AM
Views 128
20-06-2021, 04:22 AM
