JapCarForum General Discussions The JCF Lounge Engine code
Engine code
Engine code
13-08-2016, 02:29 AM
While trying to look into different engine i thought i could share some info with you
4 = 4th engine design in that family
Ax= engine family (most engines at Toyota now have two family character codes, ie 2AZ-FE)
G = head design (G is a sporty head, F is an economy head - relates to horsepower performance, ie. Last gen Celica - 1ZZFE is the base engine (130hp) 2ZZGE is the sport engine (180hp)
Z = Supercharged
T = Turbocharged
E = Fuel injection
S = Direct injection (along with fuel injection - ie 1JZFSE)
C- Equipped with emissions control systems (note: The “C” is not used if the engine was originally equipped for emissions controls.)(The C notation has been associated with California’s (USA), at that time having stricter emission standards)
U- Equipped with emissions control systems for Japan. (The U notation has been associated with the introduction of Unleaded fuel available in Japan at that time)
E- Electronic fuel injection (EFI)
F- Gear coupled cam drive; dual overhead cam (DOHC) engine: timing belt or chain drives
one cam, and “scissors” gear drives the other cam. [Narrow included valve angle]. The split “scissors” gear is a unique way to eliminate gear backlash.
G- Dual overhead cam (DOHC) engine: timing belt or chain drives both cams. [Wide included valve angel]
L- Transversely mounted in vehicle
T- Turbocharged
Z- Supercharged
Also usually the same family motors have the same mounts (4age, 4afe, 4agze)
I will continue looking into info on this over the next few weeks please add info if you can help.
13-08-2016, 02:29 AM #1
Z = Supercharged
T = Turbocharged
E = Fuel injection
T- Turbocharged
Z- Supercharged
13-08-2016, 03:50 AM
If you go to Wikipedia and type in toyota engines that comes up with a bti more info
13-08-2016, 03:50 AM #2
13-08-2016, 03:53 AM
Cheers Stav.
Here the link should anyone want it http://en.wikipedia.org/wiki/Toyota_engines
13-08-2016, 03:53 AM #3
Cheers Stav.
Replies 18
Views 1,033
09-06-2018, 10:54 PM
Last Post by Phil01
Views 234
08-06-2018, 01:42 AM
Last Post by BOOSST
Views 210
03-06-2018, 10:59 PM
Views 196
19-05-2018, 02:32 PM
Last Post by pulsar_stu
Views 226
06-05-2018, 07:41 AM
Views 760
24-04-2018, 05:26 AM
Last Post by jimxms
Views 1,187
18-04-2018, 10:12 AM
Last Post by daz@likwidart
Views 809
08-12-2017, 04:37 AM
Last Post by purplewitch
