JapCarForum Car Manufacturers Lexus/Toyota TTE supercharger upgrades
lygis
17-06-2022, 10:44 AM
Hi guys,
Just want to share with you my next upgrade, any tips and advises welcome.
Current setup:
TTE 120mm pulley
Stock injectors
Stock fuel pump
Next week's job:
160mm pulley
315cc injectors (Thanks Sparky)
Walbro 255 fuel pump
AFR gauge
Boost gauge
lygis
17-06-2022, 10:44 AM #1
Hi guys,
Current setup:
TTE 120mm pulley
Stock injectors
Stock fuel pump
Next week's job:
160mm pulley
AFR gauge
Boost gauge
18-06-2022, 05:08 AM
That's gonna produce some power be good to see the results
Sent from my K017 using Tapatalk
18-06-2022, 05:08 AM #2
reganlives
18-06-2022, 06:05 AM
What sort of management will you be using?
reganlives
18-06-2022, 06:05 AM #3
18-06-2022, 10:42 AM
A black box is generally ok I think.
I have another set of injectors if anyone else wants some!
18-06-2022, 10:42 AM #4
beamstezza
18-06-2022, 12:17 PM
Sparkystav A black box is generally ok I think.
how much for injectors posted to ireland stav
beamstezza
18-06-2022, 12:17 PM #5
beamstezza
18-06-2022, 12:19 PM
im fitting a 140mm pulley to mine now and i also have a 160mm what size belt i need for bought
beamstezza
18-06-2022, 12:19 PM #6
lygis
18-06-2022, 10:16 PM
Will try to make a video to see a difference and then will upload in here guys. I still keep black box, which I hope will be OK with these upgrades. I am not sure about belt sizes, will buy few belts and check which one fits, return the rest and get refund.
lygis
18-06-2022, 10:16 PM #7
phaebo
19-06-2022, 12:43 AM
nice setup!
I used to run 310cc injectors with 155mm pulley with only the blackbox but kept getting a check engine light because the injectors are too big for the oem ecu to handle.
it does work and runs ok but you get the check engine light on.
Better option is to get a extra ecu like greddy emanage ultimate and get it mapped on the dyno.
I use the emanage ultimate and runs great since mapping. No check engine light
phaebo
19-06-2022, 12:43 AM #8
nice setup!
lygis
19-06-2022, 06:59 AM
I heard about those ecu but it costs a fortune isnt it?
lygis
19-06-2022, 06:59 AM #9
Views 380
30-04-2022, 06:25 AM
Views 135
28-01-2022, 12:42 PM
Views 352
23-10-2021, 10:45 PM
Last Post by s cole
Views 342
15-01-2021, 10:22 AM
Views 1,081
04-09-2020, 02:32 PM
Last Post by Chris0121
Views 686
02-09-2017, 11:30 PM
