JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Reverse beeping it's not a minivan
Brad92
06-08-2022, 11:33 AM
How can I stop this irritating reverse beeping I'm half expected someone to jump out behind me in a high visibility jacket to guide me backwards! It's driving me nuts!
Sent from my D6503 using Tapatalk
Brad92
06-08-2022, 11:33 AM #1
06-08-2022, 12:23 PM
You can't it's built into the speedo unit, though leave it in place, I've removed the standard dash but still fitted a little led as its too easy to accidentally select reverse. And you'll be glad of it that day in traffic you don't reverse into soemone
06-08-2022, 12:23 PM #2
Brad92
06-08-2022, 12:47 PM
I'll take that on board stav, it does my head in though I'm used to having a close 1st/rev gearing due to my first car being a 4speed 1.3 mk5 escort.... Doesn't phase me but I suppose there is always that one time!
Brad92
06-08-2022, 12:47 PM #3
Brad92
And have to say love your booting mod
Brad92
06-08-2022, 12:47 PM #4
Brad92
Boothinge *
Brad92
06-08-2022, 12:47 PM #5
Boothinge *
07-08-2022, 08:21 AM
Cheers mate!
07-08-2022, 08:21 AM #6
Cheers mate!
07-08-2022, 08:33 AM
If it helps my supras do that too and after nearly fifteen years driving it my passenger said that beep is annoying and I said 'what beep?' ... How long have you had yours? Lol not long to go
07-08-2022, 08:33 AM #7
phaebo
07-08-2022, 12:37 PM
Hi
I had removed the bleep when i had the car for 2 days.
Remove the gauge cluster and check the wires in the plug.
Check wich wire gives 12v when you select the reverse gear.
When you found the wire just cut it and tape it. And you are done.
phaebo
07-08-2022, 12:37 PM #8
Hi
Dinho
09-11-2023, 03:52 AM
Beep is a good thing, if it wasn't for the beep I know of an ocassion where I wouldhave reversed into someone at the lights. Keep the beep Smile
Dinho
09-11-2023, 03:52 AM #9
Wayne
09-11-2023, 08:15 AM
I've nearly done that a few times too. Always wondered what the guy behind is thinking...
Wayne
09-11-2023, 08:15 AM #10
Views 412
06-02-2018, 04:05 AM
Last Post by ormi
Views 903
26-02-2017, 01:26 AM
Replies 24
Views 1,278
03-02-2017, 11:43 PM
Last Post by is300_dino
