JapCarForum Trade Area Wanted 130 or 140mm pulley
130 or 140mm pulley
130 or 140mm pulley
phaebo
05-12-2022, 08:20 AM
Hi
I am looking for 130 or 140mm pulley for the supercharger.
I want to bring my charger back to oem or at least a smaller pulley then 160mm
Thanks
Daniel
phaebo
05-12-2022, 08:20 AM #1
Hi
Thanks
Daniel
05-12-2022, 02:42 PM
U can fit a Nissan water pump pulley which will give u the 130 ur after just in case u can't get an oem
05-12-2022, 02:42 PM #2
phaebo
07-12-2022, 12:14 PM
Thx for the reply.
Do you have any more specific details on that nissan pulley?
Type and year and engine? Maybe a part nr?
I see loads of diffrent nissan pulleys but none has details about diameter etc
phaebo
07-12-2022, 12:14 PM #3
Thx for the reply.
07-12-2022, 01:36 PM
Believe it to be a navara d40 water pump pulley
07-12-2022, 01:36 PM #4
P.Lindblom
08-12-2022, 12:05 AM
Lexuspat Believe it to be a navara d40 water pump pulley
Yeah, a water pump pulley from a 2005 or newer Nissan Navara D40 looks about right. The center hole diameter is slightly smaller, but that shouldn't matter at all. Also, the Navara Pulley mounting surface is flat whereas the TTE one is slightly protruded (is that the word?). That could be solved using a spacer or even four washers if necessary.
P.Lindblom
08-12-2022, 12:05 AM #5
13-12-2022, 04:51 AM
best make sure my navara is locked up at shows now lol
13-12-2022, 04:51 AM #6
13-12-2022, 05:46 AM
Hahahaha there's a demand for them that's for sure
13-12-2022, 05:46 AM #7
Views 226
21-09-2023, 03:47 PM
Views 199
15-02-2023, 10:13 PM
Views 1,500
26-11-2022, 09:36 PM
Views 136
12-07-2022, 04:45 PM
Views 180
16-06-2022, 04:29 AM
Views 135
18-07-2021, 06:41 AM
Last Post by Xtremist
Views 270
14-03-2021, 12:15 PM
Views 231
10-03-2021, 10:47 AM
Views 144
13-12-2020, 11:56 PM
Views 242
17-09-2020, 06:11 AM
