Clutch line
Clutch line
Does anyone know the length and what fittings are on the clutch line from master cylinder to slave cylinder on the is200 as I have some 1 that is goin to make some braided lines, they are made using hel fittings and come in a range of colours.
M10x1 is the thread on the fittings mate.
The line itself has male fittings on.
I just need to measure the length and he will make it mate they will be £30 delivered
Is he making them with crushed fittings or compression fittings mate?
Compression fittings are easy to do yourself
And I've got an old measurement of 120cm but that's to the flexible bit I think
Cheers stav I might get him to make 2 up 1 as standard and 1 with that damper removed and see if there is any improvement
