JapCarForum Car Manufacturers Nissan Engine & Transmission Nissan Skyline 1996 stalling well quite a few things
Skyline1996
08-08-2023, 10:28 PM
Hello everyone,
I think i am classified enough to be in the Jap outlaws club with my Nissan Skyline 1996, shes a beauty a metallic red, body kit, specialized rims and for her age the interior has been very well looked after. I brought her about 6 months ago cheap due to no tax and needed some work doing, a very honest seller!! So i toook it on as a challenge being it is on of my favorite all time cars ever since i was a child and with all the "Fast & Furious" movies it's easy to get attached.
Anyway the reason i am here as i said before the Nissan needs some work doing i am coming across some symptoms that need sorting out asap and im not to sure what it could be, maybe nothing to major, maybe something no so good. we will see. I will drop the symptoms and specs below and hope someone can help a man out!!
SYMPTOMS
1. Engine light stays on sometimes when turning the key, then turn off back on engine light goes off.
2. Keeps stalling on a more regular basis than what any car should possibly misfiring (not 100%)
3. Whilst driving in any gear the car can start to randomly loose power for only for a short space of time
SPECS
Model: Skyline
Year: 1996
Engine: 2.0L
Transmission: 5 speed manual
Fuel type: petrol
Mileage: 99,976
I think that is pretty much all you would need but if any more specs are need just let me know and i will place them in..
I have joined another forum and they are pointing towards my ECU but i am not to sure the car would even run if that had failed?? just a thought.
Any information would be greatly appreciated guys looking forward to chatting to everyone!!
[Image: 2000px-NISSAN_SKYLINE_logo.svg.png]
Thanks
Skyline1996
08-08-2023, 10:28 PM #1
Hello everyone,
SYMPTOMS
SPECS
Model: Skyline
Year: 1996
Engine: 2.0L
Fuel type: petrol
Mileage: 99,976
Thanks
09-08-2023, 05:25 PM
welcome mate,
it could just be certain components in the ecu that have failed hence it still runs.
Im not certain; but reading the symptoms, they could all be caused by a intermittent faulty throttle position sensor maybe?
ECU light - sensing faulty sensor
Stalling - thinks the throttle is closed/not correct position so doesnt put enough fuel in
lose of power - same idea as above?
09-08-2023, 05:25 PM #2
welcome mate,
Skyline1996
09-08-2023, 07:10 PM
I never thought of the TPS This would be a cheap massive bonus and a easy fix if it is!! I will give it a check and get back to you!!
Skyline1996
09-08-2023, 07:10 PM #3
10-08-2023, 05:37 PM
no worries, the symptoms you describe point to an intermittent problem so you may initially find a fault with the tps. may be worth replacing with a second hand unit just to try?
Though remember to measure the voltage before removing the old one so you can set the new one up!
10-08-2023, 05:37 PM #4
Skyline1996
10-08-2023, 07:35 PM
I wasn't quite sure if it was the problem or not so it's booked in tomorrow to get changed then we will see if this fixes the problem.
Thanks
Skyline1996
10-08-2023, 07:35 PM #5
Thanks
Skyline1996
11-08-2023, 12:15 AM
Skyline1996 Hello everyone,
SYMPTOMS
SPECS
Model: Skyline
Year: 1996
Engine: 2.0L
Fuel type: petrol
Mileage: 99,976
I have joined another forum and they are pointing towards my ECU and say i should get an ECU chip for sale and try it out but i am not to sure the car would even run if that had failed?? just a thought.
Thanks
As luck turns out my friend come around tonight and said he couldn't see any problems with me TPS but he's not 100% but either way not long now and i should be back on the road
Skyline1996
11-08-2023, 12:15 AM #6
SYMPTOMS
SPECS
Model: Skyline
Year: 1996
Engine: 2.0L
Fuel type: petrol
Mileage: 99,976
Thanks
14-08-2023, 08:04 AM
any update mate is it all working now ?
14-08-2023, 08:04 AM #7
Jimbob-T-Lex
Moderator
1,674
12-10-2023, 01:46 AM
Any update what the issue was?
Jimbob-T-Lex
12-10-2023, 01:46 AM #8
Views 540
28-11-2019, 08:16 AM
Last Post by robsx
