JapCarForum Car Manufacturers Mazda Engine & Transmission Water pump upgrade rx8
Jimbob-T-Lex
Moderator
1,674
09-09-2023, 10:55 AM
There is only 1 aftermarket water pump "upgrade" available, the ReMedy Water Pump from Mazmart. It's designed to flow significantly smoother than the OEM pump, and eliminate cavitation at high RPMs. High coolant flow rates are important to help equalize the temperature of your engine block. Better flow means more stabilized temperatures.
Jimbob-T-Lex
09-09-2023, 10:55 AM #1
Views 190
09-09-2023, 11:05 AM
Last Post by Jimbob-T-Lex
