JapCarForum Cars, Cars, Cars! General Car Maintenance Low psi wastegate actuator help
beamstezza
17-02-2024, 12:57 PM
Hi lads looking for some help.
So iv bought a t04e turbo for my is200 build that I will be started in the coming months I have everything apart from ecu still undecided on it.
So back topic the actuator that came with the new turbo isn't opening fully until 12psi I need a actuator that's fully open at 5/6 psi and I can adjust for more boost from that later as the build progresses.
I'm wondering is there any cars that a a low boost actuator mine has the threaded shaft about 3 inches length and the two bolts on back of actuator for mounting plate if that makes sense.
Any help greatly appreciated.
Sent from my HUAWEI CUN-L01 using Tapatalk
beamstezza
17-02-2024, 12:57 PM #1
is200turbo
17-02-2024, 04:59 PM
You can buy adjustable actuators but I'm not sure how low they go.
is200turbo
17-02-2024, 04:59 PM #2
is200turbo
17-02-2024, 05:02 PM
[Image: 8be94459f698798cfd1b8106f7989131.jpg]
Something like this mate
is200turbo
17-02-2024, 05:02 PM #3
beamstezza
18-02-2024, 12:06 AM
Exactly like that mate just wonder if its any good ideally would like the brand name OEM part from some make of car that runs low psi just have no idea what car
beamstezza
18-02-2024, 12:06 AM #4
beamstezza
18-02-2024, 12:09 AM
As long as it has the same type of mounting bolts and the threaded rod it should work with my end peace
beamstezza
18-02-2024, 12:09 AM #5
