JapCarForum Cars, Cars, Cars! General Car Maintenance Brake piston knocking... need help
icemahn
01-10-2017, 07:26 AM
A while ago I noticed a knocking sound from the front nearside brake caliper everytime I hit the brakes. I took the caliper off and found out that the other piston gets stuck, thus pushes later than the other, hence, the knocking sound. I pushed and pulled both pistons several times and cleaned the rubber seal and it disappeared. Yesterday it happened again. Can anybody tell me what the problem is? Sad
Mazda CX7. 2.3 Turbo MPS. Corksport air intake. Turbo Smart dual port.
icemahn
01-10-2017, 07:26 AM #1
01-10-2017, 07:27 AM
You really need to get the caliper serviced, sticking pistons are quite common on the IS200. You can do this yourself if you're feeling confident (Toyota/Lexus even do a servicing kit with the replacement parts), or take it to a garage to do it. I would at least get both sides done at the front at the same time, even if you don't do the back ones too (the front brakes obviously take more of the strain).
01-10-2017, 07:27 AM #2
01-10-2017, 12:30 PM
i get this after very heavy braking, quite annoying!
01-10-2017, 12:30 PM #3
01-10-2017, 12:35 PM
By the way, it might be the sliders that are the problem, and need greasing perhaps ?
01-10-2017, 12:35 PM #4
icemahn
01-10-2017, 03:31 PM
Sparkystav i get this after very heavy braking, quite annoying!
I thought that was the cause. I do break heavily approaching the round about. Is it overheating causing it to stick?
icemahn
01-10-2017, 03:31 PM #5
Views 1,671
11-04-2023, 01:44 PM
Views 2,410
30-09-2020, 05:39 PM
Views 1,174
23-07-2020, 01:37 PM
Last Post by uncle bob
Views 1,684
27-12-2019, 06:37 PM
Last Post by dj0nes
Views 2,895
16-08-2019, 04:57 PM
Last Post by rsz325
Views 1,045
02-11-2018, 09:58 AM
Last Post by oilman
Replies 23
Views 3,906
20-01-2018, 05:00 AM
