car storage
car storage
Disconected would be a better way to store your battery, or buy a trickle charger and that would keep your battery fully charge.
Here a link to one..
http://cgi.ebay.co.uk/12-Volt-Car-Auto-M...1e5922fb10
I just leave mine connected when I'm not using the car, then if its flat when I get home I do as Ian has suggested with a trickle charger
I would not leave it on charge for that long, you never know what could happen when you are not there, charger goes on fire burns down garage, no more Lex :thumbdown:
Lexusboy I guess i lucky mine garage is detached so as long as the house does not burn down i take the chance.:laugh:
One of these is better to use while your away? CLICK ME?
If you can find one with a bigger output wattage it'll be better?
Most of them have a cut out/ overcharge function so it turns off when the battery is full? and pretty cheap to buy :thumbup1:
Bandit One of these is better to use while your away? CLICK ME?
