JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza led scuff plates
led scuff plates
led scuff plates
Pages (5): 1 2 3 4 5 Next
20-11-2016, 12:42 PM
bored while work is closed and waiting for the price on led scuff plates to be made up so.
drilled out all the big black plugs on the door sills and wired up some leds
[Image: SDC11283.jpg]
wrote a how to as well
so the first thing you need to do is get some led's , i got these
[Image: SDC11276.jpg]
then you need to remove the door sills from the car which is done by placine a flat screew driver under then and popping off the plastic holders....
then when you have them home you need to remove the metal plate by lifting the metal tabs from the back
[Image: SDC11269.jpg]
then you need to remove the large plastic plugs only
[Image: SDC11272.jpg]
i used a knife for this and just cut off the back of the plug so it can be popped out
so you end up like this
[Image: SDC11275.jpg]
then you need to put the metal back together with the plastic and drill the holes for the led's ... i usen a 5mm drill bit but check what size you leds are.
[Image: SDC11277.jpg]
after drilling you need to clean up the back of the plastic with a knife to remove any bits of plastic left
then you need to glue the led's into the plastic
[Image: SDC11267.jpg]
then solder it all up and check that it's all working good
then you need to put it in the car and hock it up to the light loop from the key barrel unit.
and there you go.. everybody has a light door sill
hope this helps you
jason
20-11-2016, 12:42 PM #1
hope this helps you
jason
Saraj
20-11-2016, 01:02 PM
excellent write up mate, any chance of a pic when installed??
Saraj
20-11-2016, 01:02 PM #2
20-11-2016, 01:22 PM
looks good, but is there not a danger of breaking the leds?
good work though mate!
20-11-2016, 01:22 PM #3
spikes
20-11-2016, 01:29 PM
looks good :thumbup1:
spikes
20-11-2016, 01:29 PM #4
20-11-2016, 01:35 PM
dont think so as they sit in the plate..... but time will tell. wil be putting them all in tomorrow so will take some nice photo's of this.....
[Image: SDC11431.jpg]
20-11-2016, 01:35 PM #5
20-11-2016, 01:45 PM
ah, looking from the side they look very good,
i was expecting them to stick out more. good work fella
20-11-2016, 01:45 PM #6
20-11-2016, 01:52 PM
Looking good matey, :thumbup:
20-11-2016, 01:52 PM #7
20-11-2016, 02:04 PM
sure think but everybody who wants me to do them will have to send them to me in sweden.....
took about 4 hours total....
i will be hocking them up in the morning... should not take to long as i have the power feeds there almost... have welcome lights in blue under the glove box and steering so i'm going to hock them into that. have also ordered white strip lights to go under like the puddle lights i saw on here awhile ago... thats going on the same wiring loom....
the car has a lot of lights under it now...
4x blue strips front back and sides as well as red the same and now white down the sides.....
20-11-2016, 02:04 PM #8
20-11-2016, 02:07 PM
will be doing all the badges and letters soon in blue...
like this
http://www.outlawjapclub.co.uk/forum/sho...dge&page=2
doing the whole lot
20-11-2016, 02:07 PM #9
like this
doing the whole lot
20-11-2016, 03:20 PM
sounds good mate,
20-11-2016, 03:20 PM #10
sounds good mate,
Views 524
10-07-2017, 06:34 AM
Views 1,032
28-01-2017, 02:34 AM
Last Post by N2KHL
Replies 27
Views 1,620
29-10-2016, 07:01 AM
