Bang bang!!!
Bang bang!!!
Has anyone seen this video??? :lol:
http://www.youtube.com/watch?v=lwvYqmrP_BQ
thats amazing!!!shame you cant get a charger to do that!!!!!
mmm Antilag
Marsdendean You have anti lag don't you stav??
Quote:Retarding ignition
The throttle bypass/throttle solenoid system is combined with ignition retardation and slight fuel enrichment (mainly to provide cooling), typically ignition occurs at 35-45° ATDC. This late ignition causes very little expansion of the gas in the cylinder; hence the pressure and temperature will still be very high when the exhaust valve opens. At the same time, the amount of torque delivered to the crankshaft will be very small (just enough to keep the engine running). The higher exhaust pressure and temperature combined with the increased mass flow is enough to keep the turbocharger spinning at high speed thus reducing lag. When the throttle is opened up again the ignition and fuel injection goes back to normal operation. Since many engine components are exposed to very high temperatures during ALS operation and also high pressure pulses, this kind of system is very hard on the engine and turbocharger. For the latter not only the high temperatures are a problem but also the uncontrolled turbo speeds which can quickly destroy the turbocharger. In most applications the ALS is automatically shut down when the coolant reaches a temperature of 110-115°C to prevent overheating.
Marsdendean I went in a W reg evo which had an anti lag system, was very good when he rev'd it at lights!!
How much work is it to have one on yours?
Did you notice the IS200 in the convoy.
As to the noise though, each to their own, but I really can't understand how you'd want your car to sound like that, it sounds ridiculous IMHO, as if there's something really wrong with your car. And it risks damaging the engine/turbo.
Hey ho, each to their own though ! :biggrin:
That's just ECU antilag, not proper rally antilag :thumbdown: Annoys me when the scooby boys are all like 'yeah man ive had antilag fitted its wicked' and it's HALF an antilag system which just serves to make noise, rather than providing the performance benefit it was designed to :angry:
ohdear don't get toxo started on anti-lag :p
