JapCarForum General Discussions The JCF Lounge Supercharger?
Supercharger?
Supercharger?
Pages (3): 1 2 3 Next
22-12-2016, 09:09 AM
Don't wanna sound stupid just don't know if:
A BMW Mini supercharger would fit an IS200?
I though they could be universal if you know as long as they fit, obviously not as much bhp as a normal is200 supercharger
Thanks
22-12-2016, 09:09 AM #1
Thanks
Jambo
22-12-2016, 09:16 AM
Dont know. If it WAS universal ide probably have a guess that it would have to be toyota/Lexus/anything Japanese. Although every engine is designed differently, so im guessing not. Ill let somebody speak with some knowledge tell you Smile
Latest Meets
Ace Cafe 16/10/10,
Jambo
22-12-2016, 09:16 AM #2
Latest Meets
Ace Cafe 16/10/10,
22-12-2016, 09:18 AM
Cheers anyway mate
22-12-2016, 09:18 AM #3
Cheers anyway mate
22-12-2016, 09:20 AM
I think it's a bit like a turbo, i.e. they're universal in nature but different in spec, so you need to pick one that's going to be suited to your car.
For a turbo, you need to be mindful of the way it will deal with the exhaust gases etc to produce the desired effect/bhp.
With a supercharger, it's running off the crankshaft rather than exhaust gases, but again you'd have to pick one of a suitable size (and pulley size) to generate the amount of boost that you need.
The charger in the TTE kit for the IS200 is the same as one used on a Mercedes (it's an Eaton charger).
Obviously you'd need to connect up all the pipework, and have some electronics involved as well (even if it's something as simple as an FCD).
22-12-2016, 09:20 AM #4
22-12-2016, 09:28 AM
http://cgi.ebay.co.uk/bmw-mini-superchar...3ca9a85fb5
Would this work mate?
Thanks
22-12-2016, 09:28 AM #5
Thanks
22-12-2016, 10:15 AM
Sorry but I have no idea really mate ! That looks like a smaller charger than the TTE one, think it's an Eaton M62 used in the TTE kit.
The thing is, even if you get the charger, you need to get a cradle made up for it so that it can be mounted in exactly the right place (unless you're lucky enough to get hold of a TTE one), and various other bits to get it all installed. So there's quite a bit of work and it might be no harder to try and find a second-hand TTE kit. Unless you're handy at fabricating things yourself, or know someone who is ?
22-12-2016, 10:15 AM #6
22-12-2016, 10:27 AM
Well mate, if TTE chargers are 2k
And the mini one is £200 approx.
How much is the cradle for the TTE one?
22-12-2016, 10:27 AM #7
22-12-2016, 10:32 AM
think you will be hard pushed to find a cradle mate Smile hell TTE chargers are rare as they are. Re your query on chargers think steve summed it up they are fairly universal but some may require mods iirc you could use some of the Eaton M62 is it from the Merc Kompressors?
22-12-2016, 10:32 AM #8
22-12-2016, 10:36 AM
The mini charger is an M45 charger. its definitely too small for the IS200. Its rated for 1-2l engines (so the IS one is right on the limit)
The Eaton m62 from the TTE kit is the same as the Mercedes CLK as already said.
The reason theres quite a few m45's on ebay is because the standard cooper s one is an older design (much like the tte one to be honest) and theres a simple bolt on replacement of the newer one already designed so people upgrade them.
22-12-2016, 10:36 AM #9
22-12-2016, 10:38 AM
Few of the prices here from TTE?
1; AM 27962 kit,hoses 38-46-50, 38-46-70, 50-59-110, 50-59-80, 60-70-80 no stock
2; AM 27959 housing, compressor outlet 222,88 €
3; AM 27936 ECU extension 598,59 €
4; AM 27929 valve, assy, bypass, cable operated 302,07 €
5; AM 27531 compressor unit 2019,43 €
6; AM 27966 extension, P/S cooling tube bracket 4,75 €
7; AM 27934 tube adapter for throttle body 520,41 €
8; AM 27933 intercooler assy 660,71 €
9; AM 27964 stay, compressor bracket 22,10 €
10; AM 27960 bracket, airfilter box 27,61 €
11; AM 27717 bracket, compressor 636,55 €
12; AM 27961 bracket, airfilter fixation no Stock
13; AM 27928 tube compressor to I /C (2 part type) 48,25 €
14; AM 27843 tube, bypass, 38mm 42,68 €
15; AM 27927 tube, I/C to inlet manifold (2 part type) 31,54 €
16; AM 27931 housing, airfilterbox 843,89 €
17; AM 27932 insert airfilter TOYOTA P/N 17801 - 64010 30,54 €
18; AM 27965 bracket, intercooler 5,50 €
19; AM 27939 tensioner, belt no stock
20; AM 27935 pulley (dia=130mm) 144,81 €
21; AM 27938 belt (5PK800) 28,29 €
22; AM 27930 housing, bypass to compressor 437,82 €
23; AM 27958 cable, compressor bypass, spare 30,54 €
24; AM 27963 support compressor bracket 17,90 €
Silentblock intercooler bracket x2 no Stock
Silentblock air box 20x20 M6x15 no Stock
22-12-2016, 10:38 AM #10
Views 308
04-06-2020, 05:29 AM
Last Post by reganlives
Views 835
27-01-2017, 09:55 AM
Last Post by Bandit
